Re: PARA OS MESTRES NO VAGCOM
Ok...
Afibal tá previsto isso pra alguns V6.
AQUI :arrow:
http://wiki.ross-tech.com/index.php/Immobilizer_III_Injection_Pump_Swapping
Engine Control Unit (ECU)
[Select]
[01 - Engine]
Look at the first "Extra" field. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
[Close Controller, Go Back - 06]
---OR---
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
[Done, Go Back]
Injection Pump Swapping
Prerequisites:
The NEW (Injection Pump is installed in the car.
Battery voltage at least 12.5 V.
Make sure to have the Immobilizer PIN, for the Engine Control Unit (ECU).
[Select]
[01 - Engine]
[Login - 11]
There are 2 possibilities how to enter a PIN, choose the one that applies for you.
4-digit PIN
The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234.
7-digit PIN
[Use 7-digit PIN/SKC]
Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
[OK]
VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
4-digit PIN
7-digit PIN
[OK]
[Save]
[Done, Go Back]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Start the Engine to verify the adaptation was successful.
Retrieved from "
http://wiki.ross-tech.com/index.php/Immobilizer_III_Injection_Pump_Swapping"
