Fica aqui um tópico de tudo o que seja possível de fazer download. Quantos mais melhor! :wink: ICE RNS-E (inglês) http://www.allroadfaq.com/downloads/reference/navplus/rnse_manual_.pdf RNS-D (inglês) http://www.allroadfaq.com/downloads/reference/navplus/rnsd_manual_.pdf --- A3 Manual A3 8L http://www.megaupload.com/es/?d=8IFC8HZS http://www.megaupload.com/es/?d=67DK1L0C Manutencao, sistema electrico, montagem e desmontagem A3 8L http://myweb.tiscali.co.uk/macnee/a3_interior.zip http://myweb.tiscali.co.uk/macnee/A3electrical.zip http://myweb.tiscali.co.uk/macnee/A3_Maintenance.zip --- A4 Manual A4 B6 http://rapidshare.com/files/43074150/manual_completo_audi_a4_b6.zip http://glorioso.no.sapo.pt/audi/files/Manual_A4_B6_Limo.rar A4 - plano de assistência técnica http://rapidshare.com/files/43071350/plano_assistencia_audi_a4_b6.zip Venham mais links, todo o Spam será apagado! Obrigado Migsan :wink:
Manuais A4 b5 (VÁRIOS 97-2001) Body Exterior http://rapidshare.com/files/45468237/50-1_Front_end.pdf.html http://rapidshare.com/files/45468238/55-1_Hood.pdf.html http://rapidshare.com/files/45468239/55-12_Rear_lid_VIN_8D_XA_200_000.pdf.html http://rapidshare.com/files/45468240/55-24_Rear_lid_VIN_8D_XA_200_001.pdf.html http://rapidshare.com/files/45468241/55-32_Tailgate_Avant_VIN_8D_XA_200_000.pdf.html http://rapidshare.com/files/45468242/55-49_Tailgate_Avant_VIN_8D_XA_200_001.pdf.html http://rapidshare.com/files/45468243/57-39_Central_locking_system.pdf.html http://rapidshare.com/files/45468244/57-50_Central_locking_system_Avant_repairing.pdf.html http://rapidshare.com/files/45468245/63-1_Front_bumper.pdf.html http://rapidshare.com/files/45468673/63-10_Spoiler_remove___install.pdf.html http://rapidshare.com/files/45468674/63-11_Rear_bumper.pdf.html http://rapidshare.com/files/45468675/63-16_Rear_bumper_Avant.pdf.html http://rapidshare.com/files/45468676/66-1_Protective_trim_molding.pdf.html http://rapidshare.com/files/45468677/66-2_Lower_trim_strip_front_door.pdf.html http://rapidshare.com/files/45468678/66-5_Lower_trim_strip_rear_door.pdf.html http://rapidshare.com/files/45468679/66-14_Door_mirrors.pdf.html http://rapidshare.com/files/45468680/66-22_Rocker_panel.pdf.html http://rapidshare.com/files/45468681/66-31_Wheelhousing_liner_remove___install.pdf.html http://rapidshare.com/files/45468682/66-32_Rear_wheelhousing_liner_remove___install.pdf.html Body Interior http://rapidshare.com/files/45469945/69-1_Seatbelt.pdf.html http://rapidshare.com/files/45469946/69-40_Airbag_service.pdf.html http://rapidshare.com/files/45469947/70-1_Front_door_trim.pdf.html http://rapidshare.com/files/45469948/70-23_Rear_door_trim.pdf.html http://rapidshare.com/files/45469949/70-40_Instrutment_panel.pdf.html http://rapidshare.com/files/45469950/70-72_General_trim.pdf.html http://rapidshare.com/files/45469951/70-98_Trm_Avant.pdf.html http://rapidshare.com/files/45469952/72-1_Front_seats.pdf.html http://rapidshare.com/files/45469953/72-24_Recaro_seats.pdf.html http://rapidshare.com/files/45469954/72-57_Rear_seats.pdf.html Body OBD http://rapidshare.com/files/45470987/01-1_VAG_scan_tool.pdf.html http://rapidshare.com/files/45470988/01-5_Airbag_w-o_side_air_bag_OBD.pdf.html http://rapidshare.com/files/45470989/01-69_Central_locking_system_OBD.pdf.html http://rapidshare.com/files/45470990/01-108_Interior_monitor.pdf.html Equipamento Eléctrico http://rapidshare.com/files/4547183..._On_Board_Diagnostic_through_M.Y._19.pdf.html http://rapidshare.com/files/45471833/01-1_Radio_OBD.pdf.html http://rapidshare.com/files/4547183...__On_Board_Diagnostic_from_M.Y._2000.pdf.html http://rapidshare.com/files/45471835/01-84_Multi-function_steering_wheel_OBD.pdf.html http://rapidshare.com/files/45471836/1-203_Cruise_control_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/45471837/27-1_Battery.pdf.html http://rapidshare.com/files/45471838/27-26_Generator.pdf.html http://rapidshare.com/files/45471839/27-40_Starter.pdf.html http://rapidshare.com/files/45471840/27-48_Cruise_control_system.pdf.html http://rapidshare.com/files/4547184...r_location_diagram_through_M.Y._1999.pdf.html http://rapidshare.com/files/4547289...ster_location_diagram_from_M.Y._2000.pdf.html http://rapidshare.com/files/45472898/91-1_Radio_system.pdf.html http://rapidshare.com/files/45472899/91-69_Multi-function_steering_wheel.pdf.html http://rapidshare.com/files/45472900/94-1_Three-way_halogen_headlights.pdf.html http://rapidshare.com/files/45472901/94-17_Front_fog_lights.pdf.html http://rapidshare.com/files/45472902/94-21_Front_turn_signals.pdf.html http://rapidshare.com/files/45472903/94-22_Side-mounted_turn_signals.pdf.html http://rapidshare.com/files/45472904/94-37_Steering_column_switch.pdf.html http://rapidshare.com/files/45472905/94-41_Ignition_switch_lock_cylinder.pdf.html http://rapidshare.com/files/45472906/96-1_Center_console_switches.pdf.html http://rapidshare.com/files/45473169/96-4_Interior_lights.pdf.html http://rapidshare.com/files/45473170/96-12_Interior_lights_Avant.pdf.html http://rapidshare.com/files/45473171/96-16_Lock_cylinder_heating.pdf.html http://rapidshare.com/files/45473172/97-1_Relay_panel__fuse_panel.pdf.html Injecção Combustivel e Ignição (AEB) Ignição http://rapidshare.com/files/45641452/28-1_Technical_data_spark_plugs.pdf.html http://rapidshare.com/files/45641453/28-17_Ignition_coil_system_checking.pdf.html MFI http://rapidshare.com/files/45642373/24-1_Motornic_MFI___Ignition_system.pdf.html http://rapidshare.com/files/45642374/24-99_Throttle_valve_control_module___checking.pdf.html http://rapidshare.com/files/45642375/24-123_Turbocharger_boost_control___checking.pdf.html http://rapidshare.com/files/45642376/24-136_EVAP_system_checking.pdf.html http://rapidshare.com/files/45642377/24-145_Additional_signal.pdf.html ODB http://rapidshare.com/files/45642672/01-1_ODB___DTC.pdf.html http://rapidshare.com/files/45642673/01-59_Readiness_codes.pdf.html Injecção Combustivel e Ignição (AFC) Ignição http://rapidshare.com/files/45643374/28-1_Multiport_Fuel_Injection_and_ignition_system.pdf.html http://rapidshare.com/files/45643375/28-7_Ignition_system_servicing.pdf.html http://rapidshare.com/files/45643376/28-13_Ignition_coil_power_output_stage_checking.pdf.html http://rapidshare.com/files/45643377/28-16_Ignition_coils__checking.pdf.html http://rapidshare.com/files/45643378/28-19_Crankshaft_Position_sensor_checking.pdf.html http://rapidshare.com/files/45643379/28-21_Engine_speed_sensor_checking_and_adjusting.pdf.html http://rapidshare.com/files/45643380/28-25_Engine_Coolant_Temperature_sensor_checking.pdf.html http://rapidshare.com/files/45643381/28-27_Engine_Control_Module_voltage_supply_checking.pdf.html http://rapidshare.com/files/45643382/28-29_Knock_sensors_checking.pdf.html http://rapidshare.com/files/45643383/28-33_Camshaft_Position_sensor_checking.pdf.html MFI http://rapidshare.com/files/45644127/24-1_Multiport_Fuel_Injection_and_ignition_system.pdf.html http://rapidshare.com/files/45644128/24-7_Multiport_Fuel_Injection_system_servicing.pdf.html http://rapidshare.com/files/45644129/24-16_Idle_speed_checking.pdf.html http://rapidshare.com/files/4564413...ssure_and_residual_pressure_checking.pdf.html http://rapidshare.com/files/45644131/24-24_Fuel_pump_relay_and_relay_triggering_checking.pdf.html http://rapidshare.com/files/45644132/24-29_Fuel_injectors_checking.pdf.html http://rapidshare.com/files/4564413..._testing_and_delivery_quantity_check.pdf.html http://rapidshare.com/files/45644134/24-37_Idle_Air_Control_valve_checking.pdf.html http://rapidshare.com/files/45644135/24-41_Oxygen_Sensor_control_checking.pdf.html http://rapidshare.com/files/45644136/24-43_Cold_start_driveability_problems__overview.pdf.html http://rapidshare.com/files/45644534/24-45_Oxygen_Sensor_control_checking_before_converter.pdf.html http://rapidshare.com/files/45644535/24-49_Heated_Oxygen_Sensor_before_Converter_checking.pdf.html http://rapidshare.com/files/45644536/24-53_Heated_Oxygen_Sensor_after_Converter_checking.pdf.html http://rapidshare.com/files/45644537/24-57_Heated_oxygen_sensor_removing_and_installing.pdf.html http://rapidshare.com/files/45644538/24-58_EVAP_canister_purge_regulator_valve_checking.pdf.html http://rapidshare.com/files/45644539/24-61_Sensor_for_EVAP_canister_checking.pdf.html http://rapidshare.com/files/45644540/24-64_Intake_manifold_change-over_valve_checking.pdf.html http://rapidshare.com/files/45644541/24-67_Exhaust_Gas_Recirculation_checking.pdf.html http://rapidshare.com/files/45644542/24-70_Exhaust_Gas_Recirculation_valve_checking.pdf.html http://rapidshare.com/files/4564454...culation_temperature_sensor_checking.pdf.html http://rapidshare.com/files/4564484...sition_switch_checking_and_adjusting.pdf.html http://rapidshare.com/files/45644846/24-77_Throttle_Position_sensor_checking_and_adjusting.pdf.html http://rapidshare.com/files/45644847/24-81_Mass_Air_Flow_sensor_checking.pdf.html http://rapidshare.com/files/45644848/24-85_Intake_manifold_change_over_checking.pdf.html http://rapidshare.com/files/45644849/24-88_Auxiliary_input_signals_checking.pdf.html http://rapidshare.com/files/45644850/24-111_Vacuum_connections.pdf.html OBD http://rapidshare.com/files/45645572/01-1_On_Board_Diagnostic_Multiport_Fuel_Injection.pdf.html Injecção Combustivel e Ignição (AHA) Ignição http://rapidshare.com/files/45646923/28-1_Motronic_ignition_system.pdf.html http://rapidshare.com/files/45646924/28-29_Camshaft_adjustment_system__checking.pdf.html MFI http://rapidshare.com/files/4564778...t_Fuel_Injection_and_ignition_system.pdf.html http://rapidshare.com/files/45647790/24-128_Throttle_valve_control_module__checking.pdf.html http://rapidshare.com/files/45647791/24-154_Intake_Manifold_Tuning_system.pdf.html http://rapidshare.com/files/45647792/24-164_Auxiliary_signals_checking.pdf.html OBD http://rapidshare.com/files/45648150/01-1_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/45648151/01-70_Readiness_code.pdf.html Injecção Combustivel e Ignição (APB) Ignição http://rapidshare.com/files/45649537/28-1_Ignition_system__checking.pdf.html MFI http://rapidshare.com/files/45650270/01-1_Motronic_system_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/4565027...port_Fuel_Injection_system_servicing.pdf.html http://rapidshare.com/files/45650272/24-79_Oxygen_sensor_control_checking.pdf.html http://rapidshare.com/files/45650273/24-134_Evaporative_Emission_system_checking.pdf.html http://rapidshare.com/files/45650274/24-139_Electronic_Engine_Power_Control_checking.pdf.html http://rapidshare.com/files/45650276/24-179_Additional_signals_checking.pdf.html Injecção Combustivel e Ignição (ATQ) Ignição http://rapidshare.com/files/45650545/28-1_Ignition_system_checking.pdf.html MFI http://rapidshare.com/files/45651633/24-1_Motronic_injection_system_servicing.pdf.html http://rapidshare.com/files/45651634/24-67_Intake_manifold_change_over.pdf.html http://rapidshare.com/files/45651635/24-76_Oxygen_sensor_control_checking.pdf.html http://rapidshare.com/files/45651636/24-128_Tank_ventilation_checking.pdf.html http://rapidshare.com/files/45651637/24-134_Electronic_engine_power_control_checking.pdf.html http://rapidshare.com/files/45651638/24-165_Additional_signals_testing.pdf.html OBD http://rapidshare.com/files/45652914/01-1_Motronic_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/45652915/01-15_Check_DTC_Memory_and_Erase_DTC_Memory.pdf.html http://rapidshare.com/files/45652916/01-56_Output_Diagnostic_Test_Mode.pdf.html http://rapidshare.com/files/45652917/01-66_Basic_Setting.pdf.html http://rapidshare.com/files/45652918/01-71_Code_Control_Module.pdf.html http://rapidshare.com/files/45652919/01-74_Read_Measuring_Value_Block.pdf.html http://rapidshare.com/files/45652920/01-76_Readiness_code.pdf.html Injecção Combustivel e Ignição (ATW) Ignição http://rapidshare.com/files/45653636/28-1_Ignition_system.pdf.html MFI http://rapidshare.com/files/45653940/24-1_Motronic_fuel_injection_system_servicing.pdf.html http://rapidshare.com/files/45653942/24-71_Oxygen_sensor_control.pdf.html http://rapidshare.com/files/45653943/24-107_Tank_ventilation.pdf.html http://rapidshare.com/files/45653944/24-113_Electronic_Engine_Power_Control_checking.pdf.html http://rapidshare.com/files/45653945/24-155_Additional_signals.pdf.html http://rapidshare.com/files/45653946/24-177_Vacuum_diagram.pdf.html OBD http://rapidshare.com/files/45654503/01-1_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/45654505/01-16_DTC_memory_checking.pdf.html http://rapidshare.com/files/45654506/01-19_Diagnostic_Trouble_Code_table.pdf.html http://rapidshare.com/files/45654507/01-49_Output_Diagnostic_Test_Mode.pdf.html http://rapidshare.com/files/45654508/01-58_Basic_Setting.pdf.html http://rapidshare.com/files/45654509/01-62_Code_Control_Module.pdf.html http://rapidshare.com/files/45654510/01-64_Readiness_code.pdf.html http://rapidshare.com/files/45654511/01-65_Read_Measuring_Value_Block.pdf.html Injecção Combustivel e Ignição (AWM) MFI http://rapidshare.com/files/45655008/24-1_Motronic_injection_system_servicing.pdf.html http://rapidshare.com/files/45655009/24-71_Oxygen_sensor_control_checking.pdf.html http://rapidshare.com/files/45655010/24-114_Tank_ventilation_checking.pdf.html http://rapidshare.com/files/45655011/24-120_Electronic_engine_power_control_checking.pdf.html http://rapidshare.com/files/45655012/24-163_Additional_signals_checking.pdf.html http://rapidshare.com/files/45655013/24-187_Vacuum_diagram.pdf.html OBD http://rapidshare.com/files/45655163/01-1_On_Board_Diagnostic.pdf.html http://rapidshare.com/files/45655164/01-12_Diagnostic_Trouble_Code_memory_checking.pdf.html http://rapidshare.com/files/45655165/01-51_Output_Diagnostic_Test_Mode.pdf.html http://rapidshare.com/files/45655166/01-66_Basic_setting.pdf.html http://rapidshare.com/files/45655167/01-71_Code_Control_Module.pdf.html http://rapidshare.com/files/45655168/01-74_Read_Measuring_Value_Block.pdf.html http://rapidshare.com/files/45655169/01-77_Readiness_code.pdf.html Continua ... Cordiais cumprimentos,
Boas. Já tou farto de procurar pela net e não consigo encontrar um manual para um Audi Cabriolet de 1995 (80) Alguém tem um que possa digitalizar para fazer upload? Cumps.
amigos, um pedido!! por acaso há alguma alma caridosa que possa disponibilizar os PDF de interiores do A4 B5 Limo?? já consegui download de um ou dois ficheiros mas os outros já não estão disponiveis... uma ajudinha por favor!! o que mais me interessa é o "desmantelamento" de tablier, forras, bancos, quase tudo!! abraços!!
