fiz um auto scan e deu isto:arrow:
Monday,23,March,2009,09:01:23:26365
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 170370km/105863miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1630
Coding: 00002
Shop #: WSC 06325
1 Fault Found
P1570 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04143
Shop #: WSC 06325
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 L
Component: Airbag 7 Audi 0503
Coding: 00106
Shop #: WSC 06325
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 861 A
Component: B5-KOMBIINSTR. VDO D10
Coding: 07040
Shop #: WSC 65535
Part No: IMMO
Component: IDENTNR: AUZ7Z0W0755886
IMMO-IDENTNR: AUZ7Z0W0755886
Part No: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00032
Shop #: WSC 06325
1 Fault Found
35-00 - -
o erro no address (01), tem a ver com o facto do carro estar parado ou há algum problema com o imobilizador
address (35), sera alguma fuga no circuito ou na própria bomba de vácuo
fiz também um "control module finder" foi este o resultado:arrow:
Monday,23,March,2009,09:57:04:26365
Address 01: Engine
Protocol: KW1281
Coding: 00002
Shop #: WSC 06325
Protocol: KW1281
Coding: 0273004281
Shop #: BB 24548
Protocol: KW1281
Coding: 04143
Shop #: WSC 06325
Address 15: Airbags
Protocol: KW1281
Coding: 00106
Shop #: WSC 06325
Protocol: KW1281
Coding: 07040
Shop #: WSC 65535
Address 25: Immobilizer
Protocol: KW1281
Part No: Bitte Adress
Component: e 17 eingeben
Address 33: OBD-II
Protocol: ????
Part No: OBD-II/EOBD, Protocol Keyword: $0808
Protocol: KW1281
Coding: 00032
Shop #: WSC 06325
haverá algo de errado com o address (33)
vários address tem a linha que diz "shop", isto diz respeito ao locar onde o componente foi instalado ou feito? se assim for, tudo o que for de origem tem o mesmo código de "shop"
são estas as minhas duvidas, espero não estar a ser muito ignorante, ainda sou um pouco básico
em assuntos relativos a vag-com.
abraço
Coding: 00002
Shop #: WSC 06325
1 Fault Found
P1570 - 35-00 - -
Readiness: N/A
Shop #: BB 24548
Coding: 04143
Shop #: WSC 06325
Coding: 00106
Shop #: WSC 06325
Coding: 07040
Shop #: WSC 65535
Part No: IMMO
Coding: 00032
Shop #: WSC 06325
1 Fault Found
35-00 - -
Address 01: Engine
Protocol: KW1281
Coding: 00002
Shop #: WSC 06325
Protocol: KW1281
Coding: 0273004281
Shop #: BB 24548
Protocol: KW1281
Coding: 04143
Shop #: WSC 06325
Address 15: Airbags
Protocol: KW1281
Coding: 00106
Shop #: WSC 06325
Protocol: KW1281
Coding: 07040
Shop #: WSC 65535
Protocol: KW1281
Address 33: OBD-II
Protocol: ????
Protocol: KW1281
Coding: 00032
Shop #: WSC 06325
em assuntos relativos a vag-com.abraço
