sim sao iguais, sao os d halogenio,eu tenho os bi-xenon por instalar mas como tenho d ir a inspeccao b meti estes.
ja liguei ao vagcom e k m tenha apercebido n tem nenhum erro,a unica coisa k m vem a cabeca k pode tar a fazer isto e nao ter a caixa d direcao ligada,nem montada, visto k ainda tou a espera k xegue d fora e pode tar a fazer este problema.
vou postar aki o log d erros,n s assustem com a quantidade d erros visto k o carro bateu e tou a solucionar os erros
Mileage: 90130km/56004miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 8790
Revision: --H23--- Serial number: AUX7Z0K2FNM023
Coding: 00114016030401080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023M 003009
ROD: EV_ECM16TDI02103L906023JK.rod
VCID: 306FF64B6BD6889E243-8065
4 Faults Found:
6140 - Fan 1 Control Circuit
P0691 00 [037] - Short to GND
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 90114 km
Date: 2015.05.30
Time: 00:55:22
9867 - Coolant Pump 2
P261A 00 [037] - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 90114 km
Date: 2015.05.30
Time: 00:55:36
9875 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0047 00 [165] - Short to GND
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 90114 km
Date: 2015.05.30
Time: 00:55:14
9872 - Exhaust Gas Recirculation Cooling Valve Control Circuit
P2426 00 [037] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 90114 km
Date: 2015.05.30
Time: 00:55:14
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 11422012092600FE880F04E590190051380800
VCID: 76E30053C132E6AEBEF-8023
2 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:50:30
Freeze Frame:
Count: 3
Count: 2
Count: 4608
Count: 166
Count: 44032
Count: 0
Count: 1024
Count: 0
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:50:30
Freeze Frame:
Count: 3
Count: 2
Count: 4608
Count: 8213
Count: 44032
Count: 0
Count: 1024
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000914 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78FF0E6B0B2690DEAC3-802D
2 Faults Found:
01177 - Engine Control Unit
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:55:21
Freeze Frame:
ON
00538 - Reference Voltage
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Freeze Frame:
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 46000A2FA0051AC0207040E00000015C421A29AA004DC12AE4008F800041
VCID: 387FCE6B8BA650DE6C3-806D
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:46:38
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:46:38
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 On
OFF
OFF
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H09 0250
Revision: -------- Serial number: 003JU001ED2$
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 52AB9CC3051A9A8E727-8007
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000D8C1016R
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000D8C0E191
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000060EDFD4/
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000060F30BFQ
Crash sensor for front airbag; driver side:
Serial number: 35547RB40000614810BB
Crash sensor for front airbag; passenger side:
Serial number: 35647RB40000614808BJ
5 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
9437467 - Igniter 2 for Driver's Airbag
B1001 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 90130 km
Date: 2015.05.30
Time: 00:53:40
9437696 - Igniter for Passenger's Airbag
B1002 00 [000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
000000 - SAE - Reserved by Document ISO 15031-6
P0000 00 [000] - 2005
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000012
VCID: 75E1075F1C34EDB6B75-8020
No fault code found.
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 G HW: 8P0 920 932 G
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2242K004066160
Coding: 0260128
Shop #: WSC 80093 222 69422
VCID: 387FCE6B4BA650DE6C3-806D
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 220311F1000912
Coding: 352102
VCID: 3365F94792C0B386591-8066
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:46:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:46:22
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0K2FNM023
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158086877434
VCID: 3663C05341B2A6AE7EF-8063
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Component: Tuer-SG H04 0101
Coding: 0131220
VCID: 4A9B84A3254AD24E0A7-801F
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H03 0293
Revision: 00H03000 Serial number: AUZ1Z3L2290378
Coding: 0110011
VCID: 72EB3C436D5AFA8E927-8027
1 Fault Found:
00879 - Connection to Speaker Front Right
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 5
Fault Frequency: 6
Reset counter: 50
Mileage: 90130 km
Time Indication: 0
Date: 2015.05.30
Time: 00:00:25
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 0311
Coding: F30B185A
VCID: F4E7BA5B574E74BE00B-80A1
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: 428BAC831D7A0A0EC27-8017
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 4385A98702600306C91-8016
ja vi os fusiveis do tablier mas o meu prob sao mesmo o do compartimento d motor,faltavam bues quando o comprei e n tenho a certeza s tao todos...
