Boas pessoal,hoej liguei pela primeira vez o carro ao vag com e apareceu os seguintes erros
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 06A 906 019 D
Component: 1.6l R4/2V SIMOS HS2153
Coding: 04000
Shop #: WSC 06313
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 880 A
Component: AB-KOMBIINSTR. VDO D17
Coding: 12042
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0V0109948
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 D
Component: ZV-Pumpe,Funk
Coding: 08768
Shop #: WSC 65535
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
End -------------------------------------------------------
Alguem me pode dar umas luzes,de erros mais importantes que possa ter?
Coding: 04000
Shop #: WSC 06313
2 Faults Found:
Readiness: N/A
Coding: 03604
Shop #: WSC 06435
Coding: 12042
Shop #: WSC 00000
1 Fault Found:
01176 - Key
Coding: 08768
Shop #: WSC 65535
16 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
28-00 - Short to B+
