powerman disse:
Já ligaste ao vag-com?
Deu isto tudo
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 018 BP
Component: 1,9l R4 EDC 0000SG 2110
Coding: 00002
Shop #: WSC 06313
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03143
Shop #: WSC 06313
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 880 D
Component: AB-KOMBIINSTR. VDO D08
Coding: 04040
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0W0583678
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D08
Coding: 13162
Shop #: WSC 06313
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
End -------------------------------------------------------
