Boas pessoal,hoje o meu carro(A3 8l 2002 1.9 tdi) deu um problema e preciso de opinioes para o que fazer
ia no pára arranca e o carro começou a tremer e acendeu a luz do esp,parei e desliguei o carro e ficou bom mas fiz um scan e deu isto :/
VCDS Version: Release 908.0
Data version: 20090911
Sunday,28,November,2010,21:40:39:13314
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8L03A048481 Mileage: 220120km/136776miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 FT
Component: 1,9l R4 EDC G000SG 1577
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L03A048481 AUZ7Z0B2231482
2 Faults Found:
18075 - PD Unit Injector; Cylinder 2 (N241): Electrical Malfunction
P1667 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 06435 000 00000
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 932 E
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 04040
Shop #: WSC 65535
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8L0 035 186 G
Component: concert II GRO 0008
Coding: 00000
Shop #: WSC 06435
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A3 RDW D18
Coding: 00103
Shop #: WSC 06435
Agradeço todas as opinioes...
Coding: 00002
Shop #: WSC 06435
2 Faults Found:
P1667 - 35-00 - -
P0302 - 35-00 - -
Coding: 0019970
1 Fault Found:
Coding: 00043
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 04040
Shop #: WSC 65535
Coding: 14945
Shop #: WSC 06435
1 Fault Found:
35-00 - -
Coding: 00000
Shop #: WSC 06435
Coding: 00103
Shop #: WSC 06435
