boas tardes pessoal..
e o seguinte estive a ver os erros do meu carro e aparece isto:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5334
Revision: 12345678 Serial number: AUX7Z0C8FN407H
Coding: 0000072
Shop #: WSC 06435 000 00000
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000163434
Coding: 01884F0082141000000000000000000000
Part No: 8P1 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0080
Revision: D06 Serial number: 2248CD06008360
Coding: 0004103
Shop #: WSC 00001 001 00001
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103805E535
Coding: 3D0F0B42070100
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D06 Serial number: AUX7Z0C8FN407H
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 D
Component: EPS_ZFLS Kl.10 1201
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - MIL ON
Freeze Frame:
Mileage: 0 km
Count: 1
Steering Angle: 0.00°
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 008800186D288505484A016000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001053097
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 A
Coding: 0000016
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
alguem me pode ajudar a ver o porque destes erros todos?
ou alguem me sabe explicar que erros sao?
Coding: 0000072
Coding: 0055942
Coding: 16711696
Shop #: WSC 00000
Coding: 0010602
Coding: 0000012
Coding: 0004103
Coding: 0000016
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Mileage: 0 km
Count: 1
Coding: 0000016
1 Fault Found:
Address 56: Radio
Cannot be reached
