sera k alguem me pode ajudar com estes erros
as portas da frente nao fechao com o comando mas as outras fechao
obrigadao pela ajuda
Friday,29,July,2011,19:20:10:26365
VCDS Version: Release 805.0
Data version: 20080730
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E62A106741 Mileage: 168660km/104800miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E62A106741 AUZ6Z0A0207079
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 C
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01273 - Fresh Air Blower (V2)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00000
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments Labels: None
Part No: 8E0 920 933 QX
Component: KOMBI+WEGFAHRS. RB8 D01
Coding: 00101
Shop #: WSC 00000
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 37: Navigation Labels: Redir Fail!
Part No: 8E0 035 192
Component: RNS 4.1 H06 BNO 0017
1 Fault Found:
49-00 - No Communications
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 23408
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
2 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-00 - Faulty
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
37-00 - Faulty
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00205
Shop #: WSC 63251
1 Fault Found:
69 75 76 77
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00011
Shop #: WSC 00000
1 Fault Found:
Coding: 0010602
Coding: 00012
Shop #: WSC 63351
1 Fault Found:
Coding: 00101
Shop #: WSC 00000
1 Fault Found:
01176 - Key
1 Fault Found:
Coding: 23408
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802B
2 Faults Found:
37-00 - Faulty
37-00 - Faulty
Coding: 00205
Shop #: WSC 63251
1 Fault Found:
