alguem m pode ajudar nestes erros do vag-com
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 JT
Component: 1,9l R4 EDC 0000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E63A156038 AUZ6Z0B0244887
1 Fault Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 08 -------------------------------------------------------
Controller:
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00111
Shop #: WSC 63351
No fault code found.
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller:
Address 37 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 07008
Shop #: WSC 63351
2 Faults Found:
01561 - Left Rear Door
59-00 - Can't Unlock
61-10 - Won't De-Safe - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
Readiness: N/A
Controller:
Controller:
Coding: 00111
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Controller:
Controller:
Coding: 07008
Shop #: WSC 63351
2 Faults Found:
Coding: 00060
Shop #: WSC 63351
