Bom dia,
Estou a pensar em comprar este carro e fiz um scan com o vagcom que me derem estes erros, peço sff a v/ajuda para confirmar se são graves ou não é nada preocupante:
Monday,26,November,2012,18:58:38:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 00000000 Mileage: 49300km/30633miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D550D87C835
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
000 - - - Intermittent
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F7F06850560084F01207C80
Shop #: WSC 06402 785 00200
VCID: 83010B3FBE31
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 1
Reset counter: 45
Mileage: 49288 km
Time Indication: 0
Date: 2000.00.00
Time: 18:14:40
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000764988815
Coding: 0004272
VCID: 418D413764AD
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 10
Reset counter: 43
Mileage: 49244 km
Time Indication: 0
Chassis Type: 1K0
VCID: 2D550D87C835
1 Fault Found:
VCID: 83010B3FBE31
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 45
Mileage: 49288 km
Time Indication: 0
Date: 2000.00.00
Time: 18:14:40
Coding: 0004272
VCID: 418D413764AD
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 43
Mileage: 49244 km
Time Indication: 0
