ajuda erros vag
boas alguem me poderia dizer se algo esta mal no meu carro audi a4 avant tdi 130 cv 2002, fiz o scan com o vag e deu isto:
Friday,07,May,2010,21:43:25:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 145050km/90129miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E92A162270 AUZ6Z0A0312012
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
35-00 - -
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 4001
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 00006
Part No: 62270
Component: AUZ6Z0A0312012
4 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
49-00 - No Communications
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0007
2 Faults Found:
37-10 - Faulty - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
11 Faults Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
01559 - Drivers Door
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01801 - Door Warning Lamp; Drivers Side (W30)
57-10 - Electric Circuit Failure - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
80-00 - Single-Wire Operation
01560 - Passenger Door
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 152
Component: chorus II GRO 0008
Coding: 00000
Shop #: WSC 01059
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
LOL:D:D:D:D:D:D:D:D:D:D:D:D
Faz o seguinte:
Apaga os erros e anda com o carro durante 15 a 20 minutos... E faz novo scan!
Só depois se voltar a indicar novamente essa BARBARIDADE de erros é que deves ficar MUITO preocupado... São tantos erros que até fiquei á "nora"... :assobio:
Tudo sintomas básicos de (pelo menos em tempos):
1-Bateria desligada durante um tempo prolongado;
2-Ficha da porta do condutor desligada / desencaixada;
3-Forra interior da porta do condutor desmontada e respectiva ficha da cablagem desligada;
4-entre outros....
pontos 2 e 3 efectuados com a chave na ignição ON.
Apesar de estarmos em presença de um modelo A4 8E B6 de 2002 (Avant) , é uma viatura com rede electrica de bordo Highline
com Sistema de Aviso ao Condutor FIS (Aviso de lampadas fundidas e de falta de água nos esguichos no limpa para-brisas),
Painel de Instrumentos com ecra a cores, Sem cruise control, apenas com vidros electricos á frente - atrás são manuais,
equipado na consola com radio 1DIN de cassete Chorus II e com o sistema de navegação BNS (apenas no ecra) com CD de navegação na mala.
Ah...e sem aquecimento nos bancos.... :)
boa boa obrigado pela informação ja agora tentei ver os kms com o vag e deu-me este erro alguem sabe pk?
Boas amigo, penso k esse km's são os q marca no interior, para saberes os reais tens de "ler" a centralina
Abraços
Amigo, os Kms aparecem logo na 1ª linha... Milage... Estão lá, já os vi... 145.000kms
Estas errado amigo... o que aparece na linha é o armazenado no modulo 17
os reais so mesmo na leitura directa a centralina, que segundo postou deu erro... pode ser por ter REPRO ou algo do genero..
um amigo meu tinha um A3 8L 130 cv que nao mostrava tambem, ele fez a Repro depois voltou a tira-la e Voilá, ja deixou ver...
quem o tinha fez repro e estava bloqueado esse modulo, ao mexer, desbloqueou...
Boas pessoal
alguém sabe que erro é este que tb me apareceu no scan??
o meu tb é um a4 b6 2002 e aparece o mesmo a ler os km.. penso que não é defeito, é feitio... a nossa centralina não permite a leitura dos km.
btw, sorry por desenterrar o topico, mas como o prob é o mesmo, achei que nao valia a pena abrir um novo.
tks
Pode ser apenas essa versão que não consegue.. na minha umas versões conseguem outras não...
