[AJUDA] Erros VAG
Finalmente recebi o cabo para diagnosticar a minha carrinha e aparecem os seguintes erros:
VCDS Version: Release 805.3
Data version: 20090213
Friday,26,June,2009,20:11:14:26365
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 22373 124 50361
1 Fault Found
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M003A4MR
Coding: 0033622
Shop #: WSC 06325 000 00000
1 Fault Found
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 99
Time Indication: 0
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: Komfortgerát T23 3132
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 1215
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
2 Faults Found
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
Serão este erros algo de preocupante?
Já agora, tenho tido um problema num dos farois, que em andamento, desliga-se e volta a ligar várias vezes...já retirei o farol mas não parece estar nada danificado...alguém sabe o que poderá ser?
Penso que já vinha de origem-
Ela tem farois Bi-Xenon, e no interior tem 2 botões para liguar o DRL e o outro botão não tenho a certesa :S mas penso que seja o folow-me home...mas acontece que nenhuma destas funções está a funcionar...
A Cablagem do 3ª cilindro do motor (incandescencia) parece não estar muito catolica...
Esse erro no modulo de airbags...é muito estranho...mas resolve-se, parace ser um mau contacto por ser intermitente...
O motor e switch dos vidros eletricos deve ter sido desligado com a chave na ignição algum dia (isto se tudo funcionar bem).
1º que tudo, entra em cada um dos modulos e apaga cada um dos erros e volta a entrar no modulo para ver se se mantêm.
Se se mantiverem, significa que erros permanecem, pelo que o(s) problema(s) tem de ser resolvido(s).
ELFuracon disse:
Obrigadão ELFuraco!!!
E em relação ao follow me home e ao drl?axas que pode ser alguma coisa desactivada?
deadwich disse:
Ou algum mau contacto ou....função desactivada, mas so vendo pelo vag-com.
FilipeFR disse:
Pode ser que seja um pouco tarde, mas aqui fica um site interessante (já o vi em outra thread do forum):
http://wiki.ross-tech.com/index.php/Main_Page
Obrigadão pela dica, mas estive a ver o site e não consegui perceber como activar ou desactivar o DRL e o Coming/Leaving Home...
Em relação aos outros problemas já vi que lá explica a causa e possiveis soluções.
Vou ver se consigo, mas sou muito noob nesta matéria, se alguem poder dizer os passos para eu fazer estas cenas, por favor diga alguma coisa.
ELFuracon podes dar uma ajuda?
Eu se não te importasses até me encontrava contigo durante a semana, desde que não seja demasiado inconveniente para ti!!!
Senão, se poderes dizer mais ou menos os passos no VAG eu tento tratar disso
