ola pessoal.ajuda me com estes erros pff.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 CG
Component: 1,9l R4 EDC 0000SG 1366
Coding: 00002
Shop #: WSC 63351
WAUZZZ8EZ1A048006 AUZ6Z0A0054532
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0408
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksaulenmodul 0302
Coding: 00001
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 E
Component: KOMBI+WEGFAHRS. RB4 D12
Coding: 00100
Shop #: WSC 00001
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 K
Component: Komfortgerat T01 0112
Coding: 06752
Shop #: WSC 63351
2 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0001
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
00858 - Connection: Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
End -------------------------------------------------------
obr4igado
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
P1635 - 35-00 - -
Readiness: N/A
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00001
Shop #: WSC 63351
Coding: 00001
Shop #: WSC 63351
Coding: 00100
Shop #: WSC 00001
Coding: 06752
Shop #: WSC 63351
2 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
obr4igado
