Boas pessoal, liguei um VW Vento 1.4 ca de casa ao vag-com e deu o seguinte erro...
00515 - Camshaft Position (Hall) Sensor (G40): No Signal
Possible Causes
Wiring to Camshaft Position (Hall) Sensor (G40) faulty
Possible Solutions
Check Wiring to Camshaft Position (Hall) Sensor (G40)
Check/Replace Camshaft Position (Hall) Sensor (G40)
Check/Replace Engine Control Module
Special Notes
Some older engines store this code as long as the engine is not running, if in doubt read fault codes with the engine running again.
Alguem me sabe dizer o que significa isto?
Abraço e obrigado pela ajuda
Possible Causes
Possible Solutions
Special Notes
