ajuda em erros
boas pessoal. peço desculpa cada vez que vejo um erro precisar de ajuda mas ainda nao sei bem lidar com o vag. alguem me consegue dizer o que tenho aqui?
Saturday,30,June,2012,17:15:01:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
VIN: WAUZZZ8P37A044790 Mileage: 121590km/75552miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
Component: KlimavollautomatH18 0300
Revision: 055047 Serial number: 8P0820043P
Shop #: WSC 06314 000 00000
VCID: 397D29D70B99
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 8
Reset counter: 127
Mileage: 120845 km
Time Indication: 0
Date: 2012.06.10
Time: 00:54:46
Freeze Frame:
Voltage: 12.30 V
Temperature: 21.5°C
(no units): 121.0
(no units): 98.0
Temperature: 16.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006024234
Coding: E5885F078214100000000000000000000009FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408B44336843
Subsystem 1 - Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00412717
Shop #: WSC 06314
3 Faults Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 88
Mileage: 119852 km
Time Indication: 0
Date: 2012.05.26
Time: 11:07:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 121179 km
Time Indication: 0
Date: 2012.06.18
Time: 12:37:00
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 121234 km
Time Indication: 0
Date: 2012.06.21
Time: 21:31:00
Freeze Frame:
ON
Voltage: 12.60 V
ON
ON
OFF
OFF
OFF
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D288505488A016300
Shop #: WSC 00138 261 94082
VCID: 3E773ACB12B7
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01565 - Luggage Compartment Light (W3)
007 - Short to Ground
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H58 0460
Revision: 23S Serial number: AUZ5Z4F6221970
Coding: 0001001
Shop #: WSC 65286 004 00000
VCID: EFE9578F855D
2 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 245
Mileage: 120190 km
Time Indication: 0
Date: 2012.05.29
Time: 00:23:10
Freeze Frame:
Bin. Bits: 01
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 88
Mileage: 121590 km
Time Indication: 0
Date: 2012.06.30
Time: 17:10:56
Freeze Frame:
Bin. Bits: 10000
Apaga tudo, anda com o carro 1 ou 2 dias e volta a fazer scan.
Os erros que tens são quase todos exporadicos e sem importancia.
eu fiz um scan porque o carro anda a fazer uma coisa esquesita. ha pouco tempo eu tirie a panela do meio e a final. e noto que ele de vez em quando começa a trabalhar mais grosso e no rolantim está as 1000rpm em vez de 900rpm que é o normal. mas o que é estranho é que nao é sempre. é so quando se lembra...
Não esta a fazer nada esquesito isso é o fap a regenerar
quanto aos erros maior parte deles é derivado aos led,s que tens dentro do carro
os outros apagas e depois voltas a ver se tem erros como disse o madlima29
mas a fap nao deveria trabalhar maior parte das vezes que ligo o carro? em conversa de cafe disseram me que trabalha passado 10 minutos de andar no carro
A FAP filtra sempre os gazes de escape.
A FAP apenas regenera quando o seu filtro está saturado e cheio de impurezas.
Pode de longe a longe regenerar apenas por ter efectuado muitos kilometros, mesmo que não o necessite fazer.
A regeneraçao consiste em aumentar drasticamente a temperatura da FAP atraves da queima extra de diesel, por um determinado periodo (alguns minutos) afim de incinerar as particulas nocivas ao ambiente.
o fap trabalha desde o momento que metes o motor a trabalhar
ao andar normalmente ele trabalha chama-se a isso (regeneração passiva)
depois de saturado tens de fazer uma (regeneração activa) ou seja em 3ª 2000rpm durante 10 15 min
depois tens a (regeneração forçada) ligar a maquina e regenerar o filtro via obd
