Ajuda depois de unstalar CCe volante MF
Address 01: Engine
Control Module Part Number: 038 906 019 FP
Component and/or Version: 1,9l R4 EDC G000SG 1467
Software Coding: 00002
Work Shop Code: WSC 63351
Additional Info: WAUZZZ8E32A204044 AUZ6Z0A0295393
1 Fault Found
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Saturday,14,March,2009,17:52:37:21461
VCDS Version: Release 805.1
Address 03: ABS Brakes
Control Module Part Number: 8E0 614 517
Component and/or Version: ABS/ESP front 1726
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
Readiness: 0 0 X X X
Saturday,14,March,2009,17:55:31:21461
Address 16: Steering wheel
Control Module Part Number: 8E0 953 549 N
Component and/or Version: Lenksáulenmodul 0611
Software Coding: 02042
Work Shop Code: WSC 01229
1 Fault Found
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Saturday,14,March,2009,17:56:13:21461
Address 17: Instruments
Control Module Part Number: 8E0 920 930 J
Component and/or Version: KOMBI+WEGFAHRS. RB4 D27
Work Shop Code: WSC 26200
1 Fault Found
01316 - ABS Control Module
49-10 - No Communications – Intermittent
Saturday,14,March,2009,17:56:57:21461
Address 37: Navigation
Control Module Part Number: 8E0 035 192 Q
Component and/or Version: RNS-E HIGH EU H73 0650
Software Coding: 0301112
4 Faults Found
00856 - Radio Antenna
007 - Short to Ground
00858 - Shareware Version. To Decode all DTCs
007 - Please Register/Activate
01316 - Shareware Version. To Decode all DTCs
004 - Please Register/Activate - Intermittent
01044 - Control Module Incorrectly Coded
000 - -
Saturday,14,March,2009,17:57:24:21461
Address 56: Radio
4 Faults Found
000 - -
Alguem me ajuda? A minha A4 B6 parece uma arvore de natal acende a luz do abs, travao e esp, isto aconteceu depois de instalar o CC e volante MF (tive que trocar smls + anel)
Obrigada a todos
vais ter de codificar tudo de novo devias ter tirado os codigos que tinhas antes de desmanchar
digo-te ja ´que tens ai uma trabalheira do caraças ;)
Está ai uma bela salganhada...está!!!
1º que tudo arranjar um vag-com em condições, versão 607 ou superior
total e completamente funcional, senão....
2º Codificar o ABS em condições com os procedimentos completos de login e efectuar a calibragem
do angulo de direcção (isto se o anel instalado for o apropriado).
3º Só depois passar aos erros mais simples de configuração das funções e de erros de ligações.
Assim por alto, talvez colocando o slms antigo e tirando os codigos , e depois configurando os nesse slms , de para resolver. mas nao tenho certeza, é apenas uma ideia tendo em conta que esse nao esta codificado correctamente.
Pessoal boa noticia, tinha guardado os codigos da antiga smls e coloquei-os, recalibrei o sensor e fiz mais uns testes (ABS + ESP) e ficou tudo a funcionar, mas tenho um erro que ainda continua:
1 Fault Found
35-00 - -
Que sera isto?
Boas pessoal, agora sou eu que preciso de ajuda.
Decidi instalar o volante multifunções que já tinha a algum tempo juntamente com o modulo respectivo.
Alguem me dá umas luzes de como calibrar e codificar abs e angulo de direcção.
