Boas
Tenho um problema com o carro, quando ligo a chave por vezes a luz da resistencia nao desliga, o manómetro da temperatura nao sobe e as ventoinhas disparam, pensei no termostato mas isso foi antes de correr o vag-com e aparecer esta lista de erros :roll: :roll:
Thursday,25,September,2008,19:28:43
Chassis Type: 8P - Audi A3
Address 03: ABS Brakes
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Coding: 01884F0082141000000000000000000000
Shop #: WSC 00000
Part No: 8P1 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16187408
Shop #: WSC 00000
5 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
01320 - Control Module for Climatronic (J255)
00466 - Control Module for Steering Column Electronics (J527)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 19: CAN Gateway
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Coding: 3D0F0B42070100
Shop #: WSC 06435
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 75
Mileage: 56164 km
Time Indication: 0
Date: 2008.09.15
Time: 12:33:34
Address 44: Steering Assist
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.10 1301
1 Fault Found:
Freeze Frame:
Mileage: 6160 km
Temperature: 37.0°C
Voltage: 12.30 V
Voltage: 12.10 V
Pelo que consegui pesquisar pode ser dos fios/ligaçoes CAN-Databus para o Modulo, ou entao o relé 109.
Alguem tem alguma ideia :roll: :roll:
Coding: 0023174
Shop #: WSC 06435
1 Fault Found:
Shop #: WSC 00000
Coding: 16187408
Shop #: WSC 00000
5 Faults Found:
Shop #: WSC 06435
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 75
Mileage: 56164 km
Time Indication: 0
Date: 2008.09.15
Time: 12:33:34
1 Fault Found:
Freeze Frame:
Mileage: 6160 km
Temperature: 37.0°C
Voltage: 12.30 V
Voltage: 12.10 V
