Mesmo depois de limpar estes erros persistem. Toda a ajuda sera bem vinda, obrigado. Esqueci de dizer que nao tenho luz nenhuma acesa no painel do carro.
Wednesday,05,April,2017,18:23:16:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
VIN: WAUZZZ8E66A095729 License Plate: KV55YFE
Mileage: 295160km-183403mi Repair Order:
Chassis Type: 8E (01 - My car)
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76
VIN: WAUZZZ8E66A095729 Mileage: 295160km-183403miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 AF
Component: 2.5l V6 TDI G000SG 0050
Coding: 02002
Shop #: WSC 00641
VCID: 69DE258B136A4576EA-4A3A
Subsystem 1 - Part No: 00008pba
WAUZZZ8E66A095729 AUX6Z0E0093217
No fault code found.
Readiness: 0 0 X X 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004517
Shop #: WSC 06335 000 00000
VCID: 2858608F9BE0BC7E35-807C
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x0198
Hex Value: 0x0001
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Time Indication: 0
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4022
Hex Value: 0x0004
Hex Value: 0xB098
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6CD05C9F1C98505E91-5000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 K
Component: int. Lastmodul ECE 0504
Coding: 00001
Shop #: WSC 06335
VCID: 3A7CAAC7264C3EEE53-4A3A
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M00798GS
Coding: 0033622
VCID: 3B72AFC37A7607E648-806E
Subsystem 1 - Serial number: 6332DRB40215109BC
Subsystem 2 - Serial number: 6342DRB4021DC7A5Y
Subsystem 3 - Serial number: 6352ARB40090CA8BW
Subsystem 4 - Serial number: 6362ARB4008FC04E-
Subsystem 5 - Serial number: 63729RB400A41269F
Subsystem 6 - Serial number: 63829RB400A41176D
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 01021
Shop #: WSC 06335
VCID: 418EDD2B4B9A6D3612-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 B HW: 8E0 920 951 B
Component: KOMBI+WFS 3 H12 0110
Revision: 0110 Serial number: AUX6Z0E0093217
Coding: 0006441
Shop #: WSC 00652 210 81339
VCID: 295E658B83EA85762A-5072
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 295E658B83EA85762A-5000
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BD25F831996576698-5072
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 07167
Shop #: WSC 06335
VCID: 72EC42E73EBC86AE5B-4A3A
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0506
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
End-------------------------(Elapsed Time: 06:57)--------------------------
Address 46: DTCs cleared
Address 46:8E0 959 433 CA channel 21 adapted from 0 to 1
Ross-Tech: Home
67 69 75 76
Coding: 02002
Shop #: WSC 00641
Coding: 0004517
2 Faults Found:
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x0198
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Time Indication: 0
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4022
Hex Value: 0x0004
Hex Value: 0xB098
Hex Value: 0x0001
Coding: 00000
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 06335
Coding: 0033622
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Coding: 01021
Shop #: WSC 06335
Coding: 0006441
Coding: 0006441
Coding: 00001
Shop #: WSC 00000
Coding: 07167
Shop #: WSC 06335
