Ajuda com erros vag
Boa noite, hoje liguei o vag na minha B6 e como não percebo nada dos erros que deu gostava que os experts pudessem ajudar e me explicassem se são graves. Também tentei por as portas a trancar automaticamente e não consegui pois não me deixava alterar e tentei as várias opções e nada.
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E93A295631 Mileage: 247340km/153689miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JQ
Component: 1,9l R4 EDC 0000SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E93A295631 AUZ6Z0B0455460
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04255
Shop #: WSC 06435
1 Fault Found
65535 - Internal Control Module Memory Error
00-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
4 Faults Found
01809 - Actuating Motor for Temperature Flap; Left (V158 )
41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-00 - Open or Short to Plus
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00000
2 Faults Found
01519 - Bulb for Back-Up Lights; Right (M17)
57-00 - Electric Circuit Failure
01497 - Bulb for Blinkers; Front Right (M7)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 47791 124 59924
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 TX
Component: KOMBI+WEGFAHRS. RB8 D42
Coding: 00001
Shop #: WSC 85200
1 Fault Found
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0020
1 Fault Found
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
2 Faults Found
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-00 - Won't De-Safe
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 152
Component: chorus II GRO 0008
Coding: 01010
Shop #: WSC 63351
1 Fault Found
ora nem mais, começa por apagar os erros, e volta a fazer scan passado uns kilometros, maior parte deles devem ser erros antigos..
Pois e eu só me lembrei disso depois. vou ver se faço isso e andar um dia com ela, mas como vi tantos erros pelo menos parecem assustei-me e nem sequer me lembrei de os apagar. Pelo resultado que deu será que se avizinham aí problemas com ela?
Obrigado Jimy, amanhã já apago. A versão é "VCDS Version: Beta 812.4". Também gostava que me ajudassem em relação a trancar as portas em andamento pois não consegui não me deixava alterar o valor no canal 3.
Bom dia já apaguei os erros e ele faz de novo o scan e o resultado foi este:
69 75 76 77
VIN: WAUZZZ8E93A295631 Mileage: 247430km/153745miles
Coding: 00002
Shop #: WSC 63351
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00001
Shop #: WSC 00000
1 Fault Found
Coding: 0010602
Coding: 00012
Shop #: WSC 00000
Coding: 00003
Shop #: WSC 85200
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802B
Coding: 01010
Shop #: WSC 63351
Acho que hoje já estou mais descansado, e já consegui por as portas a trancar aos 15Km/h e ao tirar a chave da ignição destrancar, andei a tentar por a luz dos ponteiros sempre ligada mas não consigo. Andei a tentar por o nome da radio no CB mas não sei como é, alguém me pode dizer como é? andei aqui a pesquisar e não consegui encontrar e ao modulo 55 penso que seja este o do xenon não me deixa aceder.
Uma dúvida isto "Labels: 038-906-019-AVF.lbl" quer dizer que o código do motor é AVF?
Tenho uma luz da marcha atrás fundida do lado direito ainda não me deu para a mudar, quanto ao xenon não tenho de origem mas tinha posto um kit mas às vezes acendia-me a luz dos travões e do ESP e tirei-o mas queria activa-lo com o VAG para tentar se já não aparecia esse erro.
então o único erro que tens neste momento é da lâmpada da luz de macha atrás..
se não tens xenon de origem, não consegues ativar seja o que for em relação a isso, muito menos consegues entrar no modulo, pois ele não existe.. e tens por ai várias resoluções para esse problema..
Para por o nome da emissora do radio a aparecer no quadrante como posso fazer, já andei por aqui a pesquisar e não encontrei nada, podem me ajudar?
