Ajuda a interpretar erro - VAG
Dei uso ao VAG e aparecem-me os erros abaixo. O carro está agora com 93345km e os erros são recentes. Será que a bateria está a fraquejar ou poderá trata-se apenas de, na altura, estar pouco carregada? O erro parece ter sido gravado ao por o carro a trabalhar (baixas rotações, será?)
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4F5 910 401 HW: 4F0 907 401 C
Component: 2.7L V6TDI G000SG 0010
Revision: --H04--- Serial number:
Coding: 0011322
Shop #: WSC 02334 785 00200
VCID: DEB71A4B772E
1 Fault Found
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 92758 km
Time Indication: 0
Date: 2012.05.14
Time: 23:02:53
Freeze Frame:
RPM: 714 /min
Torque: 54.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.86 V
Bin. Bits: 00101111
Torque: 214.5 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020871
Shop #: WSC 02325 785 00200
VCID: 65C5B5A7D278
1 Fault Found
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 92758 km
Time Indication: 0
Date: 2012.05.14
Time: 23:02:51
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4022
Hex Value: 0x0003
Hex Value: 0x165E
Hex Value: 0x00FF
Já apagas-te os erros e fizes-te novo Scan?
Se sim...
Manda verificar os sensores ABS!...
Obrigado pela dica. Não me lembrei de fazer o reset e voltar a correr o VAG. Se não der erro devo entender que foi qq coisa passageira, não?
Sim, pode acontecer ocasionalmente.
De kk maneira faz uns kilometros com o carro e depois corre o vag novamente.
Podes apagar o erro e ele desaparesse, mas qd o sistema for novamente posto à prova, pode voltar a aparecer.
Boa sorte
Lá fui eu fazer as leituras com o VAG. Apaguei os erros fiz uma leitura e deu:
03-ABS Brakes -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
VCID: DEB71A4B772E
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0020871
VCID: 65C5B5A7D278
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100653000
Coding: 0000001
Shop #: WSC 02323 785 00200
VCID: E3C12BBF5C4C
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 769 F HW: 4F0 035 769
Component: MMI Cockpit H15 0410
Revision: C61050C Serial number: AUZ6Z2G1C901H3
Coding: 0154107
Shop #: WSC 02335 785 00200
VCID: 306B14F3DD3A
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 T
Component: KLIMABETAETI
Revision: 00000031 Serial number: 00000030200263
Coding: 0008214
VCID: DBB1135F643C
Address 09: Cent. Elect.
Cannot be reached
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0MW9R5
Coding: 0013362
VCID: 295DF997FEE0
Saturday,07,July,2012,11:29:35:10074
VCDS Version: Beta 11.8.0
Data version: 20110831
Apaguei novamente e voltei a correr:
01-Engine -- Status: OK 0000
Coding: 0011322
VCID: DEB71A4B772E
Readiness: 0 0 1 1 1
Coding: 0020871
VCID: 65C5B5A7D278
1 Fault Found
Cannot be reached
Parece que o meu VAG é algo errático, não? Que conclusões tirar? Diga-se que não noto qualquer dificuldade nem na bateria nem no sistema de som.
isso pode ter sido um fusivel que queimou
pode a bateria nao estar com boa carga
pode ser varias coisas
Obrigado Rafael, vou manter-me atento a ver se algum sintoma se manfesta. Ao fim e ao cabo não noto nada, apenas o VAG me indica que algo pode andar no ar ...
