Boas pessoal,
Comprei uma 8l 1.8 a GPL á +/- 2 meses, e decidi comprar uma ficha VAG 11.11 (que suponho ser falsa pois só consigo ver os erros, não consigo mudar código nenhum).
Bem o queria era que me ajudassem tentando dizer de onde vem o problema e como posso resolve-lo.
Desde já agradeço toda ajuda/dicas que me possam dar. Obrigada
Sunday,26,October,2014,15:01:58:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Part No: 06A 906 018 AK
Component: 1,8l R4/5V MOTR HS V02
Coding: 04000
Shop #: WSC 06335
VCID: 6BDFD975199ED11
3 Faults Found:
17972 - Throttle Actuator ( J338 )
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17973 - Throttle Actuator ( J338 )
P1565 - 35-10 - Lower Stop not Reached - Intermittent
16486 - Mass Air Flow Sensor ( G70 )
P0102 - 35-10 - Signal too Low - Intermittent
Readiness: N/A
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
VCID: 56A99881B21C7C9
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
