boa noite
transcrevo novo diagnóstico
Tuesday,05,April,2016,13:32:06:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 11424012092200FA881302E5901E0042390800
Shop #: WSC 00046 412 00000
VCID: 7AFB1463F52A82CEDA7-802F
1 Fault Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 103996 km
Time Indication: 0
Date: 2016.04.04
Time: 14:58:37
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 320
Count: 43264
Count: 6144
Count: 254
Count: 0
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB004URHL
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAD95B71628F7665D9-801A
Crash sensor for side airbag; driver side:
Serial number: 3572DRB400009E38F8BB
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000A43531CP
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB40000530BEB5O
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400005283765C
Crash sensor for front airbag; driver side:
Serial number: 35547RB4000052A728CQ
Crash sensor for front airbag; passenger side:
Serial number: 35647RB4000052A771CP
No fault code found.
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 428BAC831D7A0A0EC27-8017
2 Faults Found:
01554 - Motors for Central Locking; Rear Doors; Lock
012 - Electrical Fault in Circuit
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 4385A98702600306C91-8016
2 Faults Found:
00099 - Rear Right Central Locking (Safe) Motor (V164)
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal - Intermittent
