alguém me pode ajudar a descodificar as causas destes erros?
um deles tem a ver com a pressão dos pneus certo? o outro do que pesquisei parece ter a ver com um motor do ac, ou percebi mal?
Tuesday,19,February,2013,14:05:38:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8P0CA117883 Mileage: 9320km/5791miles
Address 01: Engine (J623-CBZB) Labels: None
Part No SW: 03F 906 070 GH HW: 03F 907 309 T
Component: SIMOS10.13AH10 2655
Revision: --H10--- Serial number: AUX7Z0L0FNN08M
Coding: 001900B6232401080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM12TFS02103F906070GH 004003
ROD: N/A
VCID: 6ED8D23C0011
No ASAM data for: "EV_ECM12TFS02103F906070GH" (AU35)
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 1142201209230001881304EC901C00503E0C00
VCID: 7BFEEB684363
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 9172 km
Time Indication: 0
Date: 2013.02.16
Time: 20:20:31
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 48385
Count: 0
Count: 512
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000489 Serial number: 8P0820043BM
VCID: 78F4F4647255
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 9321 km
Time Indication: 0
Date: 2013.02.19
Time: 14:00:35
Freeze Frame:
Voltage: 12.20 V
Temperature: 29.0°C
(no units): 231.0
(no units): 166.0
Temperature: 22.0°C
Address 15: Airbags (J234) Labels: None
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU005SWE2
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 52A066CCB469
Driver's Airbag Crash Sensor:
Serial number: 3572DRB40000E4B071BY
Passenger Side Airbag Crash Sensor:
Serial number: 3582DRB40000E4B8615-
Driver's Rear Airbag Crash Sensor:
Serial number: 35128RB4000068A687BV
Passenger's Rear Airbag Crash Sensor:
Serial number: 35228RB400006829D96T
Driver's Front Airbag Crash Sensor:
Serial number: 35547RB4000068EAA06Y
Passenger's Front Airbag Crash Sensor:
Serial number: 35647RB4000068EA9B73
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0004042
VCID: 46884A9C4821
Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 Q HW: 8P0 920 932 Q
Component: KOMBIINSTR. VDO H03 0150
Revision: D0H03002 Serial number: 2240L002043834
Coding: 0276128
Shop #: WSC 00084 261 05789
VCID: 4280568C6409
Address 55: Xenon Range (J431) Labels: None
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 120104-0002-036
Coding: 1163951010022100
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 4280568C6409
Address 56: Radio Labels: None
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H05 0293
Revision: 00H05000 Serial number: AUZ1Z3M3005689
Coding: 0710011
VCID: 72E0C64C1429
ROD: N/A
VCID: 6ED8D23C0011
Revision: 00H31001
VCID: 7BFEEB684363
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 9172 km
Time Indication: 0
Date: 2013.02.16
Time: 20:20:31
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 48385
Count: 0
Count: 512
Count: 0
VCID: 78F4F4647255
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 9321 km
Time Indication: 0
Date: 2013.02.19
Time: 14:00:35
Freeze Frame:
Voltage: 12.20 V
Temperature: 29.0°C
(no units): 231.0
(no units): 166.0
Temperature: 22.0°C
VCID: 52A066CCB469
Coding: 0004042
VCID: 46884A9C4821
Coding: 0276128
VCID: 4280568C6409
VCID: 4280568C6409
Coding: 0710011
VCID: 72E0C64C1429
