Bom dia,
deixo aqui os erros da ultima leitura com VAGCOM.
Agradecia a vossa ajuda nestes erros.
Além disso tenho ha algum tempo a luz dos gases de escape acesa no tablier e não sei como desliga-la.. ja tentei apagar os erros com vag com mas mesmo assim permanece ligada.
aguardo as vossas sugestões.
Address 01: Engine
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Coding: 0000072
Shop #: WSC 06435
2 Faults Found:
19559 - Motor for Intake Manifold Flap (V157): Malfunction
P3103 - 000 - -
Freeze Frame:
RPM: 756 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.22 V
Bin. Bits: 11000100
Torque: 156.0 Nm
Torque: 0.0 Nm
16785 - EGR System: Insufficient Flow
P0401 - 000 - - - Intermittent
Freeze Frame:
RPM: 1470 /min
Torque: 60.0 Nm
Speed: 12.0 km/h
Load: 16.5 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Mass Air / Rev.: 270.0 mg/str
Mass Air / Rev.: 585.0 mg/str
Readiness: 1 2 0 0 0
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H30 0701
Coding: 008C570000141000000000000000000000
Shop #: WSC 00000
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00064784
Shop #: WSC 00000
1 Fault Found:
00153 - Left Windshield Wiper Motor (V216)
004 - No Signal/Communication - Intermittent
VAG-COM
Self-Diagnosis Log
Thursday,18,June,2009,21:15:26
Page 4
VIN Number: WAUZZZ8PX4A033345 License Plate:
Address 46: Central Conv.
Part No: 8P0 959 433 B
Component: KSG H02 0030
Coding: 0A8800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
VAG-COM
Self-Diagnosis Log
Page 5
Address 56: Radio
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H51 0060
Coding: 0001021
Shop #: WSC 06435
4 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 105458 km
Time Indication: 0
Date: 2008.09.21
Time: 01:08:15
Address 01: Engine
Coding: 0000072
Shop #: WSC 06435
2 Faults Found:
P3103 - 000 - -
Freeze Frame:
RPM: 756 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.22 V
Bin. Bits: 11000100
Torque: 156.0 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 1470 /min
Torque: 60.0 Nm
Speed: 12.0 km/h
Load: 16.5 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Shop #: WSC 00000
Coding: 00064784
Shop #: WSC 00000
1 Fault Found:
VAG-COM
Self-Diagnosis Log
Page 4
Shop #: WSC 06435
1 Fault Found:
VAG-COM
Self-Diagnosis Log
Page 5
Address 56: Radio
Coding: 0001021
Shop #: WSC 06435
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 105458 km
Time Indication: 0
Date: 2008.09.21
Time: 01:08:15
