Aguém me traduz isto?
Boas, o meu nome é Bruno e tenho um A6 4b 2.5 tdi quattro alguém me consegue traduzir isto?
Monday,04,July,2011,19:40:40:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUZZZ4BZ1N027695 Mileage: 193890km/120477miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 4B2 907 401 E
Component: 2.5l/4VTEDC 0000AG D02
Coding: 01016
Shop #: WSC 00001
VCID: 2240E8D6C295E70C
Part No: 00000059
Component: 130 106EC150_1.R75100810582
WAUZZZ4BZ1N027695 AUZ7Z0Y1504197
1 Fault Found
00550 - Start of Injection Regulation
17-00 - Control Difference
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 BG
Component: AG5 01V 2.5lTDI RdW 3535
Coding: 00001
Shop #: WSC 00000
VCID: 6DDACBEA4BCBE874
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 06257
Shop #: WSC 02325
VCID: 356A238A631B60B4
1 Fault Found
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 H
Component: A6-Klimavollautomat D64
Coding: 00063
Shop #: WSC 02325
VCID: 1F46E122F1E7CAE4
1 Fault Found
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 E
Component: Airbag Front+Kopf 1001
Coding: 00406
Shop #: WSC 02325
VCID: 326018969275778C
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 932 Q
Component: C5-KOMBIINSTR. VDO D12
Coding: 00160
Shop #: WSC 00095
VCID: 3064129E9C79459C
3 Faults Found
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D33
Coding: 06731
Shop #: WSC 02034
VCID: 2B5E05F2B55F2644
6 Faults Found
01366 - Opened Due to Crash Signal
35-00 - -
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
60-00 - Won't Safe
61-10 - Won't De-Safe - Intermittent
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
VCID: 2648F4C6AEBD1B2C
O meu problema é que o carro tem gasóleo mas não pega, para pegar tenho de colocar mais gasóleo no deposito e encher o filtro do gasóleo de gasóleo e depois anda mais uns km até gastar o gasóleo que coloquei no depósito.
Tens avarias diferentes para ele não pegar, o 1º em principio é o modulo electrónico da bomba injectora ( mais um ), e além de outros que não interessam para o caso, a boia de combustivel não está a funcionar correctamente.
Já agora aproveito o post dele para tirar uma dúvida, pratinhol, ao veres esse teste do vag com consegues saber que a bóia não esta a funcionar bem ? é que a minha também acho que está avariada mas não sei como ver no vag-com...
Porque dizes que está avariada ? não marca nada ou pensas que não marca bem ?
Não marca bem. Acende a reserva no CB apenas no último traço grande vermelho ( pelo que sei deveria acender logo no primeiro traço vermelho). Depois diz que tenho autonomia para 30 km e fiquei sem gasóleo, entretanto troquei de quadrante pq estava avariado e o problema mantêm-se. Uma vez atestei o depósito e o ponteiro não passou do meio, à terceira vez que dou à chave já subiu até ao máximo!
Poderá resolver fazendo-se uma calibragem com o Vag.
Já fizeram =S na calibragem ambos os ponteiros vão até ao fim de escala e depois param no suposto sítio certo correcto ?
