Bem, hoje peguei no carro e notei que estava a fugir bastante de traseira... Então dei umas esticadelas nas curvas e notei que estava a fugir e que o ESP não activava...
De que pode ser? Há algo que possa fazer com o VAG-COM ?!
EDIT
Aqui fica o erro... Tive que criar uma partição e usar o windows XP 32 Bits... Tinha o Windows 7 64 Bits...
EDIT
Code:
VCDS Version: Beta 912.0
Data version: 20091201
Thursday,09,September,2010,21:52:24:46862
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P64A080369 Mileage: 102890km/63932miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 J HW: 028 101 138 3
Component: R4 1,9L EDC 0000SG 5347
Revision: 12345678 Serial number: AUX7Z0C8FNO01Q
Coding: 0000071
Shop #: WSC 06435 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 A HW: 8P0 820 043 A
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000172896
Coding: 1188CF0082141001000000000001000000
Part No: 8P1 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 2248CD07013040
Coding: 0004003
Shop #: WSC 11111 111 11111
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103813076F
Coding: 3D0F0B42070100
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D07 Serial number: AUX7Z0C8FNO01Q
Shop #: WSC 51942 126 80690
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 198800186D280505C84A026000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001067000
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000016
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3C1498875
Coding: 0401001
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 80
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 80
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
