Pergunta noob...
Comprei recentemente um cabo canbus ond2 usb v704.1 ao Raptor (desde ja o mto obrigado e parabéns pela rapidez e eficiência da venda...recomendo) e a pergunta é a seguinte:
Alguem pode dar umas dicas para iniciantes, tipo onde se pode mexer, onde não, o k se pode ver tipo centralina, cv, etc...
Gracias
OK, depois de fazer um autoscan apareceram os seguintes erros. Alguem pode ajudar a decifrar?
Gracias
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 08: Auto HVAC Labels: 8P0-820-043.LBL
Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
Component: KlimavollautomatH12 0150
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 188
Mileage: 122884 km
Time Indication: 0
Date: 2007.07.04
Time: 23:34:55
Freeze Frame:
Voltage: 7.70 V
Address 46: Central Conv. Labels: 8P0-959-433.LBL
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 008800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal - Intermittent
Address 47: Sound System Labels: 8Px-035-382.LBL
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 188
Mileage: 122884 km
Time Indication: 0
Date: 2007.07.04
Time: 00:06:35
Freeze Frame:
Temperature: 25.0°C
Raw, Form. N/A: 000 000 000
Address 76: Park Assist Labels: None
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0000003
Shop #: WSC 06435
5 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 123045 km
Time Indication: 0
Date: 2007.07.18
Time: 11:44:42
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 123045 km
Time Indication: 0
Date: 2007.07.18
Time: 11:44:42
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 123045 km
Time Indication: 0
Date: 2007.07.18
Time: 11:44:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 188
Mileage: 122884 km
Time Indication: 0
Date: 2007.07.04
Time: 00:03:10
02070 - Rear Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 123045 km
Time Indication: 0
Date: 2007.07.18
Time: 09:42:43
lucianorato disse:
Queres ajuda para saberes o que :?: :?: :?: :?:
lucianorato disse:
Tem lá os codigos de avaria
E onde posso arranjar isso????
Mas mesmo assim, ninguem me pode dizer o k se passa com os meus codigos????
E ja agora quanto ás dicas???
Gostava que os meus vidros fechasem automaticamente quando fecho o carro. Penso que é possivel, mas como se faz?
Gostava de verificar/alterar a relação jantes / km/h / NAV...
E qq coisa mais dos experts k me possam recomendar...
Gracias,
SPIDER disse:
Gracias,
Mula :!: :!: :!:
