PCosta - Preciso de uma ajuda urgente - RESOLVIDO
Ora bem.
Hoje durante a noite ia eu a andar na minha B6 e qual o meu espanto quando olho para o quadrante e vejo a luz do airbag acesa. Páro o carro, desligo a chave e a luz desaparece. O mal é que continuei a andar e 5 minutos depois voltou a acender. Fui para casa e liguei vagcom e até me assustei. Tem mais erros que um teste de matemática.
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 4910
Coding: 00002
Shop #: WSC 63251
WAUZZZ8EX4A042951 AUZ6Z0C0204818
3 Faults Found
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 01024
2 Faults Found
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63251
4 Faults Found
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
Address 15: Airbags
Control Module Part Number: 8E0 959 655 B
Component and/or Version: Airbag 8.4EP 3002
Software Coding: 0010602
Work Shop Code: WSC 63251
2 Faults Found
000 - - - Intermittent
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04042
Shop #: WSC 00000
6 Faults Found
01304 - Radio
01301 - Control Module for Voice Recognition (J507)
01303 - Telephone Transceiver (R36)
35-00 - -
Address 17: Instruments
Control Module Part Number: 8E0 920 900 K
Component and/or Version: KOMBI+WEGFAHRS. RB4 D37
Software Coding: 00010
Work Shop Code: WSC 00050
Additional Info: WAUZZZ8EX4AüVüVüV AUZ6Z0C0204818
1 Fault Found
01302 - Control Module for Telematic (J499)
49-00 - No Communications
De salientar que hoje de manha andei a tentar ler o pin do imobilizador do painel de instrumentos com vagtacho e commander mas apenas fiz leituras. Não gravei nada.
Acho que a partir daí apareceu-me este vin esquisito WAUZZZ8EX4AüVüVüV no painel de instrumentos. Mas como de tarde andei no carro e nada aconteceu para mim estava tudo bem.
O log que eu tinha à 1 mês atrás era este.
VIN: WAUZZZ8EX4A042951 Mileage: 138760km/86221miles
Coding: 00002
Shop #: WSC 63251
No fault code found.
Readiness: 0 0 1 1 1
Coding: 04255
Shop #: WSC 01024
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 63251
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63251 000 00000
Coding: 04042
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 00010
Shop #: WSC 72265
Apaguei os erros mas a maior parte deles voltaram a aparecer.
Tudo no carro está a funcionar. O único mal é que a luz do airbag acende.
Que acham que aconteceu? Qual será o mal?
Re: PCosta - Preciso de uma ajuda urgente
Por acaso não a desligar e ligar bateria? A mim aconteçe-me esse testamento de erros quando desligo e ligo a bateria... Mas depois apago tudo com vag, ando um dia com a carrinha, ligo e desligo tudo quanto é funçoes e botões para testar todos os aparelhos ( desde radio a AC) e depois passo com o vag e tá limpinho.. Atenção que se apagares tudo e voltares logo a seguir passar o vag eles apareçem todos na mesma...
Ainda não desliguei a bateria. Mas tambem acabei de me lembrar disso agora. Será a 1ª coisa que farei amanha de manha.
Como tudo no carro funciona perfeitamente é que estou curioso.
Motor a 100%
Travões a 100%
Quadrante a 99% (luz de airbag acende passados uns minutos).
Volante multifunções a 100%
Climatronic a 100%
Será alguma ficha em mau contacto? Será anel de direcção? Será quadrante???????
Ou vou resolver isto á desligar a bateria e voltar a ligar?
....Atenção que se apagares tudo e voltares logo a seguir passar o vag eles apareçem todos na mesma...
Por acaso fiz isso e a maior parte dos erros apareceram. Quando liguei o motor a 1ª vez depois de apagar os erros a luz de airbag manteve-se logo acesa. Desliguei o motor e voltei a ligar e a luz desapareceu mas tambem não andei mais com o carro. Não sei se passados uns minutos irá aparecer.
Motor a 100%
Travões a 100%
Climatronic a 100%
Tu não percebeste o que disse.. Eu disse que QUANDO por uma razão qualquer tenho que desligar e voltar a ligar a bateria costuma apareçer uma carrada de erros.. Eu não desligo a bateria para resolver erros..
De qualquer forma podes sempre desligar seguindo estas indicações da Audi ( é os procedimentos deles):
1-Ao se mexer em baterias (desligar cabos):
1.a) Chave fora da ignição.
1.b) Desligar borne negativo.
1.c) Desligar borne positivo.
2-Ao se voltar a reconectar a bateria:
2.a) Ligar borne positivo.
2.b.) Colocar a chave na ignição, posicao ON.
2.c) Ligar borne negativo.
( fiz copy/paste de um texto escrito pelo ELFuracon, a quem agradeço a partilha de informação)
Depois apaga tudo no vag, andas umas horas, liga e delisga tudo quanto seja botões, numa de testar os aparelhos ( radio, gps, ac etc etc) e depois faz scan novamente.
Chave em On antes de ligar negativo?
Isso não vai fazer estragos. É que a maior parte dos aparelhos começam logo a funcionar quando encostar o borne negativo e se houver mau contacto não sei não!
Isso não vai fazer estragos. É que a maior parte dos aparelhos começam logo a funcionar quando encostar o borne negativo e se houver mau contacto naão sei não!
A avaliar pelos grandes conheçimentos do user ELFuracon, tenho toda a confiança no que ele escreve...
Não te esqueças de andares uns bons kms para testar tudo e só depois passas novo scan
Amnha vou fazer o seguinte.
Desligo a bateria e volto a ligar. Depois faço scan com vagcom. Vou dar uma volta para ver se acende a luz do airbag e volto a fazer scan.
Mas o que me faz confusão é este vin que dá no quadrante (WAUZZZ8EX4AüVüVüV).
Estou desconfiado que o problema vem daqui. Que raio será isto?
faz isso... limpa tudo com vag ( clear all DTCs) e depois anda uns bons KM, não é 6 duzia deles... e testa tudo não te esqueças.. depois diz resultados...
Ok. Se não funcionar já se está mesmo a ver onde este carro vai parar.....
.....à Audi. :duhh::duhh::duhh::duhh:
Lá vão mais umas pastas sem ser em mods. :mad:
Se der erro no airbag, deve ser o costume... fichas debaixo do banco.. existe um procedimento depois para isso...
Cheira-me a Quadrante novo... repara:
01794 - Control Module: Incorrect Chassis (VIN) Number
Possible Causes
Control Module was never adapted to a Car (New Control Module)
Control Module was originally adapted to a different Car (Used Control Module)
Possible Solutions
Check Vehicle Identification Number (VIN) of Control Module and Car
Perform Vehicle Data Learning
Special Notes
When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Heating/Air Conditioning, perform Vehicle Data Learning (Adaptation).
When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Airbag 8.4, perform Vehicle Data Learning (Adaptation).
When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Airbag 9.41, perform Vehicle Data Learning (Adaptation).
When the Vehicle Identification Number (VIN) in Airbag and Instrument Cluster matches, try clearing the fault code. If it does not clear, ignore it as long the airbag warning light is not active. For further details see TPI 2007313.
When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Steering Wheel, perform Vehicle Data Learning (Adaptation).
When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Seat Adjustment, perform Vehicle Data Learning (Adaptation).
When found in Audi A4/S4/RS4/Cabriolet (8E/8H) (if the above Procedures do not succeed):
When the Vehicle Identification Number (VIN) in Instrument Cluster does NOT match the real one, the VIN stored in the Instrument Clusters might be lost or corrupted. This problem can usually only be resolved by installing a new Instrument Cluster or finding somebody who is able to repair the old one. Additional detailes describing this problem can be found in TPI 2004680.
De qualquer das formas, tenta o tal "Vehicle Data Learning" nos respectivos modulos... BOA SORTE!
O problema é simples......qualquer "mexida" houve de certeza no painel de instrumentos, o VAGtacho ou qualquer outro.....(a gente nao sabe o que o vag-tacho faz, mesmo só em leitura).
Em sequencia disso, o painel ficou sem o VIN number que tinha antes.....e agora todos os modulos que estavam pareados com o VIN anterior estão todos "baralhados".
Ao fazer o Learn VIN Number, os modulos vao ficar com o mesmo "lixo" do VIN do quadrante, alem de não resolver os probelmas de comunicação entre eles.
O quadrante foi retirado do sitio? Eu tentaria retira-lo e desligar as fichas durante algum tempo (exemplo 5 minutos) e voltar a ligar as fichas e certificar que as mesmas ficam bem encaixada e não
há pinos "tortos". depois é ver o resultado e fazer um scan, apagar os erros modulo por modulo.
No final, se não resolver, para mim quadrante...já era...
Obrigado Nelson. Já me passou isso pela cabeça.
Está bem que eu queria um quadrante com fis a cores mas será mesmo isso? É que está tudo a funcionar no quadrante!
Como se faz "Vehicle Data Learning" com vagcom?
Quanto custará um quadrante recondicionadao a cores para B6 na Audi?
