Os erros do meu 8l - Parece uma biblioteca
Boas pessoal fui testar hoje os erros da minha a3 8l e isto no vag-com apareceu-me milhentos erros! Será que me podem dar uma ajuda a conseguir resolver alguns?
Sunday,19,December,2010,18:11:36:21461
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 290020km/180210miles
Address 01: Engine Labels: 038-906-018-AGR.lbl
Part No: 038 906 018 A
Component: 1.9l R4 EDC 00SG 1001
Coding: 00002
Shop #: WSC 06313
2 Faults Found
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 B
Component: A3 KLIMAVOLLAUTOMAT_D72
Coding: 03143
Shop #: WSC 06313
1 Fault Found
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 601 A
Component: AIRBAG VW3 V01
Coding: 00065
Shop #: WSC 06313
1 Fault Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 860
Component: AB-KOMBIINSTR. VDO D07
Coding: 00040
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: AUZ7Z0T0044073
IMMO-IDENTNR: AUZ7Z0T0044073
1 Fault Found
01176 - Key
07-00 - Signal too Low
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D16
Coding: 13130
Shop #: WSC 00000
6 Faults Found
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
Realmente podes ter ai muitos erros gravados mas antigos, possivelmente foram ja reparados, quando a bateria falha a centralina tem por habito carregar
erros e mais erros gerados pela falha de energia...
Segue ai o conselho do Luciano...
acho que muitos erros desses foram provocados pela bateria ou seja quando trocas-t possivelmente....
apaga e corre o programa de novo daqui a uns tempos
