need same help
VCDS Version: Beta 812.4
Data version: 20090214
Wednesday,01,April,2009,01:59:21:26365
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC G010SG 6337
Revision: 12345678 Serial number: AUX7Z0D9FNF0BA
Coding: 0000072
Shop #: WSC 00046 412 26214
2 Faults Found
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 16.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 000 - - - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 26.0 Nm
Speed: 58.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 00046 412 262144
1 Fault Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 105413 Serial number: 8P0820043D
Shop #: WSC 00046 412 1114112
3 Faults Found
01487 - System Function Test
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 101424 km
Time Indication: 0
Date: 2009.07.06
Time: 16:03:09
Freeze Frame:
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 101424 km
Time Indication: 0
Date: 2009.07.06
Time: 16:03:27
Freeze Frame:
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 113088 km
Time Indication: 0
Date: 2010.01.10
Time: 00:21:15
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001089878
Coding: 258A5B168214120000000000000000000001FE0E5C
Shop #: WSC 00046 000 40960
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00046
6 Faults Found
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
01321 - Control Module for Airbags (J234)
00483 - Control Module for Auxiliary Air Heater
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 K HW: 8P0 920 930 K
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2249DD03037101
Coding: 0004108
Shop #: WSC 00044 261 55639
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001049140430
Coding: 7D0F0B42070100
Shop #: WSC 00046 000 32768
2 Faults Found
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 113088 km
Time Indication: 0
Date: 2010.01.10
Time: 00:21:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 113088 km
Time Indication: 0
Date: 2010.01.10
Time: 00:21:20
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D03 Serial number: AUX7Z0D9FNF0BA
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000016
Shop #: WSC 00046 412 1064960
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.10 1401
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 1880005E6D288505480A010000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found
01299 - Diagnostic Interface for Data Bus (J533)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001183644
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000016
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000000 Serial number:
Coding: 0000001
Shop #: WSC 00046 000 40930
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1510891
Coding: 0401001
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
5 Faults Found
Presico de alguma ajuda pessoal a ver o que se passa com isto!
estes dias apareceu me o simbolo do ESP acessa no painel, juntamente com a luz mto intensa no painel do climatronic.....
E ultimamente a luz do xenon anda me a falhar tipo psicadelico chegando a desligar acontecendo mais vezes na optica do lado direito.....
Estou aqui desconfiado que a bateria esta a dar as ultimas, contudo retira-a e verifica o contacto de massa que fica por baixo da mesma, apaga os erros com o Vag e volta a fazer um Scan
O xenon é original? Se não é. Os balastros estão isolados correctamente? :S
Isto é só uma idéia, pode não ter nada a ver mas....
Vitor Faria disse:
tenho tambem a sensaçao que a bateria ta a dar as ultimas mas... como sei que ta a dar o p€ido?!
eu apaguei os erros e desapareceram mas ha sempre dois que ficam do A/C
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 101424 km
Time Indication: 0
Date: 2009.07.06
Time: 16:03:09
Freeze Frame:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 101424 km
Time Indication: 0
Date: 2009.07.06
Time: 16:03:27
EgasRS disse:
O xenon é de origem e ontem parecia que as luzes nem queriam ligar nao sei porqué :S
Ps. antes de ontem andei a ver os cabos e pareceu me estar tudo ok
Crazy Inside disse:
Pegas num Multimetro e medes a voltagem, e se conseguires mede a amperagem, e depois compras um multimetro novo :green: :green: :green: :green:
Com o carro a trabalhar ou desligado? Se for desligado está boa.. Se for a trabalhar já começa a precisar de outra...
EgasRS disse:
Desligado....! Ligado 14.22v
O xenon nao sei o que se passa com ele realmente desliga se principalmente a otica do lado direito as vezes passado 2min de a ter ligado...
nao me tava apetecer desmontar a otpica porque da muito trabalho :S
Opinioes aceitam se...
Abraço pessoal
