Motul 100% Synthetic Oil 5 LTR. 505.01
MOTUL
100% Synthetic
Volkswagen Gasoline and Diesel engine oil 100% Synthetic TYPE OF USE Specially designed for cars which follow fixed oil drain intervals (15000 km in Europe) powered by Tdi, Turbo Diesel engines fitted with or without Unit Injector (Volkswagen PD), without Diesel Particulate Filter (DPF) or gasoline engines. Suitable for any types of fuel : leaded, unleaded gasoline and diesel fuel. PERFORMANCES APPROVALS VW 505 01 – 502 00 – 505 00 PERFORMANCE Meets Official approvals of VW guarantee the quality of the product development and manufacturing process. Synthetic base stock provides outstanding lubrication properties in order to handle additional load on valve train due to unit injector actuation, minimizes friction and ensures resistance at high temperature observed in modern engines. Avoid wear on valve train in order to preserve engine performances. "Mid SAPS" technology for a better compatibility with last generation on catalytic converters. Anti-oxidation, Anti-wear, Anti-corrosion, Anti-foam properties
( Compatible with OEM part number: 842451 / 842451 )
