VCDS Version: Release 908.0
Data version: 20090911
Wednesday,24,March,2010,14:38:50:13314
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 191500km/118992miles
Address 01: Engine Labels: None
Part No: 038 906 012 A
Component: 1,9l R4 EDC 0000SG 2801
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03143
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 G
Component: Airbag Front+Seite 1007
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 930 D
Component: KOMBI+WEGFAHRS. M73 D10
Coding: 00140
Shop #: WSC 00000
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0X8213015
Ident.-Nr. Wegfahrs.:AUZ5Z0X8213015
No Faults Found
or a communication error occurred
(aqui tinha um erro na primeiro teste que era: 00779-outside air temp sensor(G17)
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 K
Component: ZV-Pumpe, Funk D11
Coding: 12864
Shop #: WSC 06435
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00957 - Key 3
como suspeitava a minha massa de ar ja ardeu nao foi??
e o resto malta algo grave ? e para apagar os erros tenho duvida onde e amigos
para ver os km reais e onde diz mileage edc15-16?
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Coding: 13304
Shop #: WSC 06435
Coding: 03143
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 00140
Shop #: WSC 00000
Part No: Ident
No Faults Found
Coding: 12864
Shop #: WSC 06435
5 Faults Found:
35-00 - -
00955 - Key 1
00957 - Key 3
