correcto !
mas o scan da minha carrinha deu erros que não estão aí ?!
alguém sabe alguma coisa ?
o scan que fiz foi este :
VAG-COM Version: Release 704.1
Data version: 20071016
Friday,05,December,2008,20:30:46:59303
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: None
Part No: 028 906 021 CE
Component: 1.9l R4 EDC 00SG 0803
Coding: 00002
Shop #: WSC 06325
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
00519 - Intake Manifold Pressure Sensor (G71)
28-00 - Short to Plus
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Part No: 8E0 614 111
Component: ABS 5.3 FRONT D11
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Part No: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D72
Coding: 04143
Shop #: WSC 06325
Address 15: Airbags Labels: 8A0-959-655.LBL
Part No: 8A0 959 655 B
Component: Airbag V AUDI D01
Coding: 00766
Shop #: WSC 06315
Address 17: Instruments Labels: 8D0-919-0xx-17.LBL
Part No: 8D0 919 034
Component: B5-KOMBIINSTRUMENT D10
Coding: 00140
Shop #: WSC 54321
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: None
Part No: 4A0 953 234 F
Component: IMMO AUZ9Z0T8951518 D77
Coding: 00000
Shop #: WSC 00000
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01363 - Switch for Central Locking; Driver's Door (F59)
27-00 - Implausible Signal
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
End --------------------------------------------------------------------------------------------------
