help- erros vag
  • Thread starter Thread starter feztaz
Boas pessoal hoje fui ligar o menino a maquina e ia-me assustando tanto o medidor de massa de ar e os airbags já me tinham aparecido quando apaguei os erros... agora voltaram em força. help (ah a egr desliguei via vag com n sei se tem alguma coisa a ver com o erros e os airbags foi o antigo dono q n me disse nada, agr ja e tarde)
Friday,03,August,2012,21:09:25:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 332170km/206400miles
Part No: 038 906 018 BP
Component: 1,9l R4 EDC 0420AG 2110
Coding: 00001
Shop #: WSC 06313
VCID: 65C5B5A7D7A1
5 Faults Found:
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-10 - - - Intermittent
17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
P1549 - 35-10 - - - Intermittent
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
VCID: 366722EB3A87
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03143
Shop #: WSC 06313
VCID: 295DF997FB39
No fault code found.
Address 15: Airbags Labels: Redir Fail!
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 418D41376349
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00595 - Crash Data Stored
35-00 - -
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 860 D
Component: AB-KOMBIINSTR. VDO D10
Coding: 00040
Shop #: WSC 00000
VCID: 397D29D70B99
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0661119
IMMO-IDENTNR: AUZ7Z0W0661119
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D05
Coding: 00000
Shop #: WSC 51241
VCID: 397D29D70B99
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
1- Esse Carro Tem a Centralina em Modo Caixa automática devia ter algum Problema ao pegar
2- MAF Avariada
3- N75 Avariada,Nao Notas que o Carro nao puxa decentemente?
4- Valvula da EGR Avariada
EGR Valve (N1: Open Circuit or Short to Ground
5- Modulo ABS não consegue Comunicar Não tens a Luz do ABS ligada?
01315 - Transmission Control Module 49-00 - No Communications
6- Esse Carro deve ter tido algum acidente no qual os Airbags Dispararam...
7- Tens alguma fuga na Bomba de Vácuo do Fecho centralizado ou Então tens os Grafites Partidos...
Corrijam me no que tiver errado
Andar anda, Ainda xD
Mesmo hoje dei 200 =X
a parte do airbag e da maf ja desconfiava, em relaçao a n75 tenho vindo a descubrir alguns tubos rotos... ja la vao 2... acho q primeiro vou mudar os tubos todos...
Este erro da egr nc me tinha aparecido... sera por a ter desligado via vag-com?
em relaçao ao abs n noto nada... faz o abs normal... apenas de x em quando parece q o pedal treme por 5 segundos quando viro o volante e travo suavemente( nao e constante )
Porra qq dia monto um carro novo... dasssss
