Thursday,09,April,2009,14:41:11:21461
VCDS Version: Release 805.1
Address 35: Centr. Locks
Control Module Part Number: 4B0 962 258 K
Component and/or Version: Zentralverrieg.,DWA D35
Software Coding: 06987
Work Shop Code: WSC 11720
1 Fault Found
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Thursday,09,April,2009,14:41:57:21461
Address 01: Engine
Control Module Part Number: 4B2 907 401 F
Component and/or Version: 2.5l/4VTEDC G000SG D04
Software Coding: 01015
Work Shop Code: WSC 02325
Additional Info: WAUZZZ4B32N040136 AUZ7Z0A1947372
Additional Info: 00003059 130 106LC150_1.V77593781188
1 Fault Found
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to Plus - Intermittent
Readiness: N/A
Thursday,09,April,2009,14:42:37:21461
Address 15: Airbags
Control Module Part Number: 4B0 959 655 M
Component and/or Version: Airbag 8.4E 3003
Software Coding: 0000306
1 Fault Found
01218 - Side Airbag Igniter; Passenger Side (N200)
002 - Lower Limit Exceeded - MIL ON
Thursday,09,April,2009,14:43:04:21461
Address 37: Navigation
Control Module Part Number: 4B0 035 192 P
Component and/or Version: RNS-E HIGH EU H44 0650
Software Coding: 0502111
Work Shop Code: WSC 00000
3 Faults Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
00625 - Shareware Version. To Decode all DTCs
004 - Please Register/Activate
01303 - Shareware Version. To Decode all DTCs
Thursday,09,April,2009,14:44:06:21461
Address 17: Instruments
Control Module Part Number: 4B0 920 933 M
Component and/or Version: KOMBI+WEGFAHRS. VDO D07
Software Coding: 00160
Work Shop Code: WSC 00001
2 Faults Found
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
49-10 - Please Register/Activate - Intermittent
Ora cá está... São só estes erros.... agora EXPLIQUEM-ME POR FAVOR
1 Fault Found
35-00 - -
Address 01: Engine
1 Fault Found
Readiness: N/A
Address 15: Airbags
1 Fault Found
3 Faults Found
2 Faults Found
