Ora viva pessoal, cm era de esperar vou postar os erros do meu argolas.
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 019 FT
Component: 1,9l R4 EDC 0200SG 1527
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L83A011825 AUZ7Z0B2114505
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 J
Component: A3 KLIMAAUT
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 06435
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 E
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 04040
Shop #: WSC 00050
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 8L0 035 186 G
Component: concert II GRO 0008
Coding: 00000
Shop #: WSC 06435
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
End -------------------------------------------------------
Nao me parece k seja nada de grave, ou estou enganado?
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Coding: 0019970
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 04040
Shop #: WSC 00050
Coding: 14945
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 06435
1 Fault Found:
