boas pessoal.. no fim de reparar o meu argolas do sinistro k tive ainda encontrei estes erros. alguns sao faceis de encontrar tipo sensor de temepratura do motor e do ar exterior, os farois desnivelados mas outros nao consigo descodificar. os entendidos k se cheguem a frente
VAG-COM Version: Release 704.1
Data version: 20071016
Sunday,18,October,2009,19:07:46:59303
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8L03A041952 Mileage: 122850km/76335miles
Address 01: Engine Labels: 038-906-019-130.LBL
Part No: 038 906 019 FT
Component: 1,9l R4 EDC 0000SG 1577
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L03A041952 AUZ7Z0B2206448
3 Faults Found:
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 08: Auto HVAC Labels: None
Part No: 8L0 820 043 L
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: None
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14913
Shop #: WSC 06435
2 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00013
Shop #: WSC 06435
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
Coding: 00002
Shop #: WSC 06435
3 Faults Found:
P1161 - 35-00 - -
P1156 - 35-00 - -
Coding: 00043
Shop #: WSC 06435
2 Faults Found:
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
Coding: 14913
Shop #: WSC 06435
2 Faults Found:
35-00 - -
Coding: 00013
Shop #: WSC 06435
1 Fault Found:
35-00 - -
