Boas pessoal... alguem me ajuda e diz o que se passa com estes erros da minha Avant????
Saturday,21,April,2007,18:49:12
VAG-COM Version: Release 607.3-UD
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN Number: WAUZZZ8E52A148608
Address 01: Engine
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E52A148608 AUZ6Z0A0270689
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect.
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags
Part No: 8E0 959 655
Component: Airbag 8.4E 4001
Coding: 0010602
Shop #: WSC 63351
Address 16: Steering wheel
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02002
Shop #: WSC 63351
Address 17: Instruments
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 00100
Shop #: WSC 08906
Address 46: Central Conv.
Part No: 8E0 959 433 AG
Component: Komfortgerát T87 0315
Coding: 07008
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Address 56: Radio
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
01042 - Control Module; Not Coded
35-00 - -
End --------------------------------------------------------------------------------------------------
69 75 76 77
Address 01: Engine
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags
Coding: 0010602
Shop #: WSC 63351
Coding: 02002
Shop #: WSC 63351
Coding: 00100
Shop #: WSC 08906
Coding: 07008
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802B
Address 56: Radio
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
35-00 - -
