Boas pessoal tenhu aqui umas duvidas corri o meu carro com vag com e deume isto
VCDS Version: Release 805.1
Data version: 20081017
Thursday,05,November,2009,21:12:54:21461
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A112360 Mileage: 122500km/76117miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1343
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A112360 AUZ7Z0A1838793
1 Fault Found
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435 000 00000
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 931 J
Component: AB-KOMBIINSTR. VDO D12
Coding: 06140
Shop #: WSC 02120
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15211
Shop #: WSC 06435
5 Faults Found
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Depois apaguei os erros que ja deviam estar antigos e voltei a correr com vag com mas apareceme na mesmo o erro no modulo 35 mas nao noto quaquer deficiencia no carro nem no fecho centralizado.
Thursday,05,November,2009,21:22:47:21461
Coding: 00002
Shop #: WSC 06435
Coding: 0019970
Coding: 00043
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 06140
Shop #: WSC 02120
Coding: 15211
Shop #: WSC 06435
5 Faults Found
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
O que acham que possa ser?
Abraços
Coding: 00002
Shop #: WSC 06435
1 Fault Found
Coding: 0019970
Coding: 00043
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 06140
Shop #: WSC 02120
Coding: 15211
Shop #: WSC 06435
5 Faults Found
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Coding: 00002
Shop #: WSC 06435
Coding: 0019970
Coding: 00043
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 06140
Shop #: WSC 02120
Coding: 15211
Shop #: WSC 06435
5 Faults Found
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Abraços
