Erros na minha A4 B6 [ AJUDA ]
Boas
Ontem passei com o VAG-COM 805.1 na minha menina e deu estes erros :oops:
Quem ajuda :)
Sunday,22,March,2009,12:30:10:21461
VCDS Version: Release 805.0
Data version: 20080529
Address 17: Instruments
Control Module Part Number: 8E0 920 900 G
Component and/or Version: KOMBI+WEGFAHRS. RB4 D26
Software Coding: 00000
Work Shop Code: WSC 00001
Additional Info: WAUZZZ8E92A176153 AUZ6Z0A0292351
1 Fault Found:
01320 - Control Module for Climatronic (J255)
49-10 - No Communications - Intermittent
Sunday,22,March,2009,12:32:56:21461
Address 17: Instruments (8E0 920 900 G)
12:32:55 Group 016: Adaptation Channels 47 && 48
47 Adaptation Channel
121 Soot Entry
48 Adaptation Channel
47 Thermal Load
Sunday,29,March,2009,13:56:31:21461
Address 46: Central Conv.
Control Module Part Number: 8E0 959 433 AG
Component and/or Version: Komfortgerát T87 0315
Software Coding: 16928
Work Shop Code: WSC 63351
Additional Info: 8E1959801B Tõrsteuer.FS BRM 0002
Additional Info: 8E1959802B Tõrsteuer.BF BRM 0002
5 Faults Found:
01320 - Can't Decode, CODE File Not Loaded!
49-10 - Can't Decode, CODE File Not Loaded! - Intermittent
01561 - Can't Decode, CODE File Not Loaded!
59-00 - Can't Decode, CODE File Not Loaded!
61-10 - Can't Decode, CODE File Not Loaded! - Intermittent
01562 - Can't Decode, CODE File Not Loaded!
59-10 - Can't Decode, CODE File Not Loaded! - Intermittent
61-00 - Can't Decode, CODE File Not Loaded!
Sunday,29,March,2009,13:59:46:21461
Address 08: Auto HVAC
Control Module Part Number: 8E0 820 043 A
Component and/or Version: A4 Klimaautomat 0712
2 Faults Found:
01273 - Can't Decode, CODE File Not Loaded!
30-10 - Can't Decode, CODE File Not Loaded! - Intermittent
29-00 - Can't Decode, CODE File Not Loaded!
Sunday,29,March,2009,14:03:47:21461
1 Fault Found:
Sunday,29,March,2009,14:05:39:21461
Address 08: Auto HVAC (8E0 820 043 A)
14:05:38 Group 004: Right Temperature Flap Control Motor (V159)
24.0 Current Value
19.0 Specified Value
22.0 Minimum Position (Cooling)
235.0 Maximum Position (Heating)
Sunday,29,March,2009,14:11:43:21461
Esta morta né :?: :?:
