Erro esp e a luz do travao a piscar
Bom dia a todos preciso de ajuda se for possível, o meu audi a4 b8 começou acender a luz do esp e do travao a piscar e o relantim aumenta.Se desligar o carro e volta a ligar normaliza as vezes mas volta sempre a dar o mesmo erro.Limpei os erros com o vagcom mas os mesmos sintomas voltam.Deixo o log para alguém me possa ajudar.Muito obrigado
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 KC HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3208
Revision: 11H01---
Coding: 0104002C18072120
Shop #: WSC 00021 216 90384
ASAM Dataset: EV_ECM20TDI03L906022KC A01004
ROD: EV_ECM20TDI03L906022JT.rod
VCID: 70E467AAAB74059E7F5
3 Faults Found
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 103192 km
Date: 2015.03.20
Time: 19:33:35
2813 - Accelerator Position Sensor (G79)
P2122 00 [044] - Signal too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 103177 km
Date: 2015.03.19
Time: 16:16:33
2815 - Accelerator Position Sensor 2 (G185)
P2127 00 [044] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 103177 km
Date: 2015.03.19
Time: 16:16:33
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 06335 000 00000
VCID: 78F45F8ACB045DDEB75
2 Faults Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 17
Mileage: 103177 km
Time Indication: 0
Date: 2015.03.20
Time: 18:29:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0009
Hex Value: 0x6397
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 17
Mileage: 103177 km
Time Indication: 0
Date: 2015.03.20
Time: 18:29:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x27A2
Hex Value: 0x0013
Hex Value: 0x0297
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: Redir Fail!
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030200
VCID: 3A708582B5888FCE811
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0107.08.080693
Coding: 34000000
VCID: 4280FD62DD58C70ED91
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000090725
Coding: 2600509141342F200701008000001D0D439C074800010101000000
Shop #: WSC 06335 123 12345
VCID: 2F66A4D67ECA5A6626F
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 070808 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52930821205394
Coding: 100003
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD1891L/
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7C839AB7BCB1FE93D
Crash sensor for side airbag; driver side:
Serial number: 6334MSME3E312C5CP
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3E75301EL
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME780F0B45R
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME1F024F18O
Crash sensor for front airbag; driver side:
Serial number: 63732SME7405213CX
Crash sensor for front airbag; passenger side:
Serial number: 63832SME6F05381E9
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JB100033
Coding: 000017
VCID: 3E788992A9A0A3EEBD9
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 C HW: 8K0 920 900 C
Component: KOMBIINSTR. H16 0224
Revision: 00100000 Serial number: 9DS350488
Coding: 0F07100002000008060000
VCID: 2A50B5C245283F4EF11
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G087218250
Coding: 000303
VCID: 4688E172F170FB2EF59
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007572845
Coding: 011002204000410001
VCID: 4084F76AD354D51ECF5
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113475781
Coding: 0100062020390040012002
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007546348
Coding: 011002204C00410001
VCID: 3F86F496AEAAAAE6B6F
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000001155509
Shop #: WSC 00000 000 00000
VCID: 346CABBA97EC79BE5BD
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 17
Mileage: 103177 km
Time Indication: 0
Date: 2015.03.20
Time: 18:29:13
Freeze Frame:
Voltage: 12.30 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range Labels: None
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 346CABBA57EC79BE5BD
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1102397
Coding: 0500048204028500815B070000
VCID: 37769CB6869A92A67EF
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000100178880
Coding: 010002204000210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000100042207
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 A HW: 8T0 862 335 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005021126
Coding: 0010390
VCID: 38749F8A4B849DDE775
