Duvidas VAG-COM
Boas amigos...
Fiz hoje o primeiro Scan com o VAG e estou com dúvidas face ao "relatório" apresentado e gostava que me dessem uma ajudinha....
Em relação ao Km's é normal haver um pequeno diferença entre os valores do Vag e o que marca no no interior (No meu caso marca 131880 no Vag e 131885 no interior)?
O "relatório" apresentado foi:
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E83A357388 AUZ6Z0C0030297
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 00076
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Interruptor da luz de stop - cablagem interruptor da luz de stop ?
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 M
Component: Lenksáulenmodul 0209
Coding: 01042
Shop #: WSC 00076
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 00001
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1211
Coding: 06986
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63351
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Condutor de dados CAN, instrumentos Código(s) de avaria armazenado(s) noutro(s) sistema(s), cablagem, módulo de controlo dos instrumentos ?
00852 - Loudspeaker(s); Front
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63351
Abraços
...Em relação ao Km's é normal haver um pequeno diferença entre os valores do Vag e o que marca no no interior (No meu caso marca 131880 no Vag e 131885 no interior)?
Os KMS que te aparecem no topo do relatório do scan são os que te aparecem no quadrante sempre ARREDONDADOS a 10.
Para tentar ver os que estão na Centralina é:
- APPLICATIONS
- READ EDC15/16
- READ
Ou aparece uma mensagem a dizer que não é possível ou aparece uma janela com os KMS/MILHAS.
Quanto aos erros, apaga tudo e volta ao ataque daqui a uns dias e "preocupa-te" apenas com esses que voltarem a aparecer.
