Devo preocupar-me?
Corri um teste com o VAG-COM e apareceram-me os seguintes:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E32A077828 AUZ6Z0A0191100
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 00020
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 11111
1 Fault Found:
01320 - Control Module for Climatronic (J255)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors Aqui tenho o RNS-E instalado
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06720
Shop #: WSC 63351
2 Faults Found:
01804 - Door Warning Lamp: Rear Right (W38)
28-10 - Short to B+ - Intermittent
Address 56 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors Este acho que é pela ausência do Chorus II
End -------------------------------------------------------
Não querendo abusar da boa vontade de quem domina o vag, como é que faço desaparecer estes erros?
Salvo melhor opinião, esses erros do climatronic devem-se ao facto de teres tido o sistema electrico ligado enquanto tinhas os cabos de ligação ao climatronic desligados. Depois de tudo ligado, tenta fazer o clear dos erros e corre de novo o scan para verificação.
Esses erros apareceram derivado de teres sacado fora o Klimatronic...apagas os erros e em principio está tudo ok :wink:
Sendo assim, já não sei....quando eu meti o meu rns-e esses erros aparecem...entretanto limpei-os e nunca mais aparecera,....agora se a ti continuam a aparecer mesmo quando os limpas :roll: :roll: :?
Tambem tenho o mesmo problema com o climatronic!!
O mesmo erro e nao consigo eliminar
Sempre que ligo o AC/Climatronic o carro custa a pegar
Alguem ja resolveu este stress??
cumps
cumps
Mas tu ligas sempre o kilatronic A/C antes de pores o carro a trabalhar :S
