Para aquele pessoal que nunca sabe se fechou o carro isto pode dar jeito, activar o som quando se fexa / abre o carro.
**IMPORTANT** BEFORE MAKING ANY CHANGE ENSURE YOU RECORD YOUR PREVIOUS SETTINGS!
This will allow you to both set it back 'as was' if required or get out of jail if it goes wrong.
To enable this you will need access to VAGcom.
Module 09 - Central Electronics. and select Coding, goto the Long Coding Helper
Check Byte 08 and remove Bit 7
You can now use the DIS menu system to control beeb on arm, or beeb on unlock.
MOD is at your own risk, i take NO responsibility for any problems.
This worked fine on my 07 V6 and my 09 TTS.
Este topico foi retirado do forum (http://www.tt-forum.co.uk/) e foi criado pelo user: Toshiba
