boas!
consegui fazer um auto scan e deu-me estes resultados:
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 805.1 Data version: 20080823
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Monday,16,March,2009,10:32:51:21461
VIN: TRUZZZ8N121034257 License Plate:
Mileage: 82670km-51368mi Repair Order:
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUZZZ8N121034257 Mileage: 82670km/51368miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 8N0 906 018 AQ
Component: 1.8L R4/5VT G 0002
Coding: 11500
Shop #: WSC 66565
TRUZZZ8N121034257 AUZ5Z0B4205136
1 Fault Found
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: None
Part No: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 01236 785 00200
1 Fault Found
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
No fault code found.
VCDS
Self-Diagnosis Log
Page 2
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 A
Component: Airbag Front+Seite 5000
Coding: 01102
Shop #: WSC 01236
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 930 Q
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 00044
Shop #: WSC 32557
1 Fault Found
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267
Component: Zentralverrieg. D06
Coding: 06736
Shop #: WSC 01236
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00009
Shop #: WSC 01236
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 186 G
Component: concert II GRO 0008
Coding: 00202
Shop #: WSC 01236
esta bom ou esta mau??
o que devo fazer de seguida ja que vi que tem umas falhas?
abraço
VCDS
www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log
Coding: 11500
Shop #: WSC 66565
1 Fault Found
Coding: 0019469
1 Fault Found
Coding: 00040
Shop #: WSC 01236
VCDS
Self-Diagnosis Log
Page 2
Coding: 01102
Shop #: WSC 01236
Coding: 00044
Shop #: WSC 32557
1 Fault Found
Coding: 06736
Shop #: WSC 01236
Coding: 00009
Shop #: WSC 01236
Coding: 00202
Shop #: WSC 01236
abraço
