cArEkA disse:O QUE E ESTE ERRO![]()
Address 08: Auto HVAC
Control Module Part Number: 8E0 820 043 A
Component and/or Version: A4 Klimaautomat 0712
Software Coding: 00001
Work Shop Code: WSC 63350
1 Fault Found
01273 - Fresh Air Blower (V2)
29-00 - Short to Ground
Crazy Inside disse:Possible Causes
Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Short of open circuit in wiring to Fresh Air Blower (V2)
Climatronic Control Module (J255) malfunctioning
Possible Solutions
Check Fresh Air Blower (V2)
Perform Output Test (Check Air Vents while Blower is active)
Check Meas. Blocks while Blower is active
Check Control Module for Fresh Air Blower (J126)
Check wiring and connectors
Vitor_Ponte disse:se tiveres o motor da sofagem em curto circuito deves ter fusiveis queimados também, ja foi verificado isso?
cumps
