Ajuda a descodificar erros no VAG COM
Boas meus amigos :green:
O VAG deu-me as seguintes menssagens, quem me ajuda?
VAG-COM Version: Release 607.3-UD
Saturday,18,October,2008,19:00:33
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 028 906 021 CE
Component: 1.9l R4 EDC G00SG 0803
Coding: 00002
Shop #: WSC 06335
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Part No: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 7590
1 Fault Found:
00668 - Supply Voltage Terminal 30
36-00 - Open Circuit
Address 08: Auto HVAC
Part No: 8D0 820 043 H
Component: A4-KLIMAVOLLAUTOMAT_D65
Coding: 00043
Shop #: WSC 06335
2 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Address 15: Airbags
Part No: 8A0 959 655 C
Component: Airbag V AUDI D00
Coding: 01022
Shop #: WSC 06324
Address 17: Instruments
Part No: 8D0 919 033 N
Component: B5-KOMBIINSTRUMENT__D11
Coding: 00140
Shop #: WSC 00138
Address 25: Immobilizer
Part No: 4A0 953 234 F
Component: IMMO AUZ9Z0T5820612 D77
Coding: 00000
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
00668= pode ser da bateria
01272= sao os motores de abertura dos respiradores um bocado de wd40 resolves
o primeiro verifica se a bateria esta em condiçoes
o outro tiras o porta luvas e lubrificas os motores que isso passa ;)
Mestre rafael disse:
basta só tirar o porta-luvas ó Mestre ;) ;) ;) :?: :?: :?:
é que a minha sofre dos mesmos sintomas :roll:
