Obrigado pela atenção . . Entao meto o 5w40 sintetico norma 505 certo?? Isso faz muda de 10 em 10 mil??
Errado! Nunca na vida coloques um óleo desses no teu carro... o que deves colocar é o
VW 505.01, pode ser 5w40 ou 5w30, nenhum deles é totalmente sintético apesar de a maioria das embalagens o dizerem.
No Maximo 10 mil mas cada um sabe de si
mas não lhe digas para usar o 505, a não ser que queiras que ele dê cabo do motor
Deixo aqui a lista e a sua explicação, a vermelho os que podem ser usados!
Volkswagen Motor Oil Specifications
VW 500.00
Volkswagen specification for multigrade engine oils for gasoline engines with SAE 5W-X/10W-X viscosity. This is an "old" oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 501.01
Conventional motor oils suitable for some VW engines built before MY 2000. This is an “old” oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 502.00
Oil for gasoline engines. Successor of VW 501.01 and VW 500.00 specification. Recommended for those which are subject to arduous conditions. It must not be used for any engines with variable service intervals or any which are referred to under other specifications.
VW 503.00
Long-life gasoline engine oil for VW cars with WIV (system for longer service intervals). Also meets ACEA A1, SAE 0W-30 or 5W-30 specification.
VW 503.01
This specification is specifically for Audi RS4, Audi TT, S3 and Audi A8 6.0 V12 models with outputs of more than 180bhp, running with variable service intervals (30,000km or 2 years). Now superceeded by the VW 504.00 specification.
VW 504.00
The VW 504 00 specification superceedes the VW 503 00 and VW 503.01 specifications. VW 504 00 oils are suitable for engines meeting the demands of Euro IV emissions standards.
VW 505.00
Passenger car diesel engine oil specification, minimum performance level CCMC PD-2. Lists viscosities SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max. evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max. evaporation loss.
VW 505.01
Special engine oil for VW turbodiesel engines with pump-injector-unit and for the V8 Commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 specification.
VW 506.00
These oils are suitable for diesel engines with extended service intervals of up to 50,000km / 2 years. Not for use on engines with a single injector pump. Oil change is indicated by the electronic service indicator. Viscosity is SAE 0W30.
VW 506.01
These oils are especially for "Pumpe-Düse" (unit injector or "PD" engines) running on extended service intervals (30,000 - 50,000km / 24 months). Oil change is indicated by the electronic service indicator.
VW 507.00
Low SAPS oils suitable for Euro 4 engines and almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines. Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil.
VW 508.00/509.00
This specification combo (508.00 for petrol, 509.00 for diesel) requires a 0W20 viscosity, fuel economy oil with long life additives. These specifications are NOT backward compatible with the eariler VW specifications. Recommended for the new 2.0 TFSI 140 kW and 3.0 TDI CR 160 kW VW/Audi engines.
