VW Eletricista Audi
Resolver umas cenas que me dão erro no a3 que tenho
instalei o Acc e o lane assist e agora tenho erros no carro.
Fui a bosch e tenho isso
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (2D2D2-CXXB) Labels: None
Part No SW: 04L 906 056 D HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2510
Revision: 22004001
Coding: 02194012432401092000
Shop #: WSC 20890 002 1048576
ASAM Dataset: EV_ECM16TDI03004L906056D 002006
ROD: EV_ECM16TDI03004L906056CQ_AU37.rod
VCID: 2EB6D6B77918DD6267F2AB-807A
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 60636000000863
Coding: 12F162A224240A6D017B060241C82548462450806082A4F2024100788008
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 791C35EBF0D6CADA828060-802C
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000876659
Coding: 03000104002000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 328EC2C76D20F98203CA7F-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061606301779
Coding: 04040A42C24122FD43844004001C07A80008000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 04E2541F87148732E11679-8050
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160208 043 0580
Serial number: 160220190438
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 61447609
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Component: E1 - LDS MQB H05 0032
Serial number: 02 12 2015 00000025
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291606300563
Coding: 0000050001
Shop #: WSC 09059 003 1048576
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3C92ECFFBF643FF2D966C1-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 09061503212718
Coding: 00001B00FE0339
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3A9EEAE7B55001C2CB7AD7-806E
5 Faults Found:
15360768 - Component Protection
U1101 00 [009] - Active
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:48
1024 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:48
0284 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:48
1027 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:48
1028 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:48
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R1HGWWN
Coding: 98CCC0000C0000005C5400CA004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 4B70BF23EACA884A60CC6A-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 303 16
Component: SideSensor_Df 001 0887
Serial number: 357670000003C358C91
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 303 16
Component: SideSensor_Pf 001 0887
Serial number: 358670000002B358C91.
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 503 16
Component: SideSensor_Dr 001 6149
Serial number: 3516502B51F93A03B33A
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 503 16
Component: SideSensor_Pr 001 6149
Serial number: 3526502AF1F93A04B05K
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 902 16
Component: FrontSensor_D 001 6149
Serial number: 3556502C11F3538392EG
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 502 16
Component: PedP_Sensor_D 001 6149
Serial number: 22865029F1F1FF32C10S
Coding: 2D2D2D
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 502 16
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B71F353825066
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 401 002 16
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A31F1FE312287
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 EF HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 06031608490478
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 02EE52079D008902D32A4F-8056
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 871 S HW: 8V0 920 871 S
Component: KOMBI H03 6423
Coding: 07A40A002B8800080600E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 4C72BC3FEFC48F7269C611-8018
1 Fault Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:56
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004542008
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 23 02 2016 A0071383
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001602222986
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0080
Serial number: 0365205998
Coding: 030321
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU37.rod
VCID: 389AF0EF8B5C13D23D0E3D-806C
Lane Change Assistant 2:
3 Faults Found:
388357 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
Mileage: 45929 km
Date: 2018.03.08
Time: 12:00:47
730378 - Warning Lamp for Lane Change Assistance in Driver-Side Ext. Mirror
C1116 15 [008] - Open or Short to Plus
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 45929 km
Date: 2018.03.08
Time: 12:10:25
730634 - Warning Lamp for Lane Change Assistance in Passenger-Side Ext. Mirror
C1117 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 45929 km
Date: 2018.03.08
Time: 12:10:25
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 210116EAG10603
Coding: 00108B204000040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 43609703C29A400A989CB2-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 4462941FC7944732A196B9-8010
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 150116EAE06466
Coding: 001083204000040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 426E9207DD80490293AA8F-8016
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 018A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 750439DBDCCEAEBAE6A85C-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 864 C HW: 8V0 035 864 B
Component: MU-S-N-ER 042 0461
Serial number: A3F00303161136
Coding: 01730301FF00000021110001000A00002F0004040100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 3B90EFE3BA6A38CAD06CDA-806E
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 D HW: -----------
Component: ECE 2016 --- 0054
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30FZ4E
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: ALJAL116011600030256
End-------------------------(Elapsed Time: 03:55)--------------------------
Alguma dica?
Qual o carro?
Um 8V , certo?
Se sim, tens de desbloquear a proteçao componente das peças que colocaste na audi.
Ja retirei a proteção,
A questão é que codificação devo ter para isso funcionar?
Mexer no 01 (engine)
Mexer no 03 (ABS)
agora depois de um scan dá-me isso
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F BB BC
VIN: WAUZZZ8V7GAXXXX Mileage: 47131km-29285miles
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Revision: 22004001
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 2E53B8BA71174334BA-807A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79F95BE6F8D9548C5F-802C
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
VCID: 326BACCA652F67D4DE-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: 4FE8C81800PAG0MUFU01
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
ROD: EV_BCMBOSCH_015.rod
VCID: 04073A128F1B19643C-8050
Control Unit For Wiper Motor:
Coding: 0A47F7
Rain Light Recognition Sensor:
Coding: 00006C
Light switch:
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Coding: 0000050001
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3C7782F2B76BA1A404-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Coding: 00001B01FE033B
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3A7B84EABD5F9F9416-806E
6 Faults Found:
1807 - No Enable Indentifications Active
B2032 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
Control Module temperature: 25 °C
Voltage terminal 15: 12.4 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1024 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
0284 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1027 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1028 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B95D12EE2C5161CBD-801E
Side Sensor Driver Front:
Coding: 2D2D2D
Side Sensor Passenger Front:
Coding: 2D2D2D
Side Sensor Driver Rear:
Coding: 2D2D2D
Side Sensor Passenger Rear:
Coding: 2D2D2D
Front Sensor Driver:
Coding: 2D2D2D
Pedestrian Protection Driver:
Coding: 2D2D2D
Pedestrian Protection Passenger:
Coding: 2D2D2D
Pedestrian Protection Center:
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Coding: A408
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 020B3C0A950F17540E-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Coding: 07A40A002F8000080600E8001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 4C97D232E7CB1124B4-8018
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 67
Mileage: 47080 km
Date: 2018.03.12
Time: 10:03:40
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
ROD: EV_GatewLear_013_VW37.rod
Alternator:
Multi Function Steering Wheel Control Module:
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Coding: 030321
ROD: EV_LaneChangAssis_VW51.rod
VCID: 387F9EE283538D84E0-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0080
Serial number: 0368405631
Coding: 030321
3 Faults Found:
388357 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 64
Mileage: 47080 km
Date: 2018.03.12
Time: 10:03:40
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 47080 km
Date: 2018.03.12
Time: 10:09:49
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 47080 km
Date: 2018.03.12
Time: 10:09:49
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4385F90ECA95DE5C45-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Coding: 8103
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 4487FA12CF9BD9647C-8010
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428BFC0AD58FD7544E-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E157D6D4C130EC3B-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B7581EEB265A69C0D-806E
Data medium:
Display unit 1 for multimedia system:
Multimedia Operating Unit:
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 150216BBF03042
Coding: 000083204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 4581E716C4A1E06C6B-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 150216BBF0304B
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:01)--------------------------
